Question about Refrigerators
Magic chef model rc203pd no water getting to ice and water outlet
I am getting no water to the ice or water outlet. i am not sure but i don't seem to have any power to the water control valve. i can hear the ice auger turning when the switch is activated adn the light works. i have water coming into the dual control valve but none going out. i just bought this fridge used and don't know if it worked before since it was not hooked up
  • 2 more comments
  • dartking50 Jul 06, 2008
    i did check the power to the water outlet. there are two connectors each have two wires,one black one white one brownand a jumper that joins them. there does not seem to be any power to the switch. it did work for a bit. because there is ice in the tray,only a few cubes.
    i am getting no water to the ice or water outlet. i am not sure but i don't seem to have any power to the water control valve. i can hear the ice auger turning when the switch is activated adn the light works. i have water coming into the dual control valve but none going out. i just bought this fridge used and don't know if it worked before since it was not hooked up
    Comment by dartking50, posted on Jul 06, 2008
    again before i replace the water control valve,there is no power to the valve so how do i know it is bad
    not being an electrician where does the power come from,is it through the switch first.
  • Refrigerators Master
  • 19,396 Answers
It is quite a common case, there is no power because the solenoid that power the valve is defective, replace the solenoid.
Posted on Jul 06, 2008
  • 868 Answers
First off,you will not have voltage at the valve unless your checking it while you are activating the switch on the door where you hold your glass up to.Secondly the Ice Maker is going to have to be sending the voltage when its ready to fill the tray with water,so....you see now how hard your chances are to get a reading when it fills up about 2 times a hour.
    Scholar:
  • 135 Answers
Sir,,check this ,,this will help u get a replacement
http://tigerdirect.partsearch.com/Model/Maytag/Magic+Chef/RC202TAV.aspx
    Guru:
  • 1,342 Answers
The valve may be defective.
Here's a good troubleshooting guide
Posted on Jul 05, 2008
    Master:
  • 638 Answers
Unknowingly you know the right solution the water control valve should receive power then only further procedure can be made.or if you get water control valve repaired your unit starts working properly.reply for further suggestions.
    President:
  • 2,712 Answers
You will have to replace the control valve
  • 796 Answers
Its likely the dispenser board is bad.
  • isaac johny
    isaac johny Jul 05, 2008
    Here is the new board for your model:
    Dispenser control board http://www.repairclinic.com/referral.asp...
    If you order the control board with the link I provided and it doesn't
    fix the problem, you can return it for a full refund within 30 days.
    Guru:
  • 1,894 Answers
Yes.
please check the power supply to your water control valve.
check from the place where it receives power.
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
How do you put water in the magic chef model number mcim22sv portable icemaker?
Remove ice bucket and add water to fill line at the back of the water tank
Jan 17, 2013 | Magic Chef Portable Ice Maker
Magic Chef microwave oven will not work. No lights come on, seems to be no power. I checked the outlet - seems OK. Model # MCD990W
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 11, 2010 | Magic Chef MCD990W Microwave Oven
Magic Chef refrigerator model CTF1923. erratic ice production
As long as your freezer temperature is at 0 you should have steady ice production. If you have to jumper the ice maker to get it to harvest then you most likely have a bad thermostat. That coupled with the leak issue really warrants just replacing the entire ice maker.
Be sure to ask for pricing on both the ice maker by itself as well as the complete kit. You may be surprised to find that the entire kit (including a new valve, line and bucket) will cost lest than just the ice maker by itself.
Jun 13, 2010 | Refrigerators
Need instruction or manual for the Magic chef ice maker model
Hope this helps. This is the link where you may be able to download
http://www.partselect.ca/Search-Suggestions.aspx?term=MCIM30TW
Nov 22, 2009 | Magic Ice Cream Makers
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
I have a counter top ice maker. I can't seem to locate parts or find out if this machine even exists. It stopped making ice last summer. It cycles but does't add water to the cube maker. You have to add...
Magic Chef Counter Top Ice Maker.
just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
Mar 18, 2008 | Magic Chef Refrigerators
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
