Vizio VP50 HD 20A stand removal -- manual shows removing 4 screws from the rear of the tv on 2 sides and the stand easily pulls off -- cant budge the stand at all-- dont want to force the stand off -- maybe more screws are involved?
techman
  • 3130 Answers
SOURCE: rca hdlp50w151 screen removal
Almost every set comes apart a differant way. My advice would be to go ahead and get the service manual if you want to do this type of service yourself as then you will know for sure if your taking apart the proper se quence of parts in the order they should be. As I remember a lady customer once , started to take apart her projection set, and did not not ewhat to take apart and it ended up costing herover a grand as she took out some critical screws that made the main mirror inside the set to drop and break and caused damage to two of the main projection lenes!!! My advice to you here is get tyhe service manual as I wish i had it to give you but I do not. If you invest like I think 20 to 30 bucks and go to http://www.servicemanuels.net you can be sure of what your doing and how to do it for your set! Please report back and tell us how myou made out?!
Posted on Oct 05, 2006
  • 979 Answers
SOURCE: Removal of stand to wall mount tv.
Slide clips are used on a lot of these sets, and they require a small, flat blade to release the catch on both sides to allow removal...accordianman
Posted on Mar 09, 2008
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
How do I remove stand?
see page 7 of the manual http://www.curtisint.com/html/custservice/manuals/PRO_PLCD3992A_EN.PDF
look at the bottom center of the TV back, it shows 4 to 6 screws that hold the stand in place. remove the 4 perimeter screws then if necessary the inner 2 screws.
Feb 22, 2015 | Proscan PLCD3992A 39 in. LCD HDTV
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
    1. Unplug all of the cables and cords from your GV42L FHDTV10A.
    2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
    3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
    (This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
    4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
    5. Gently remove the stand base
    6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
    Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
    How do you remove the stand on a samsung 19inch lcd tv..
    There are 4-6 screws that must be removed. look on the rear of the TV for screws at the base of fairly deep holes. They require a #2 phillips head screw driver. Remove all of the screws and then get a friend to hold the base whild you pull the tv straight up about 6-7 inches. Joe
    Mar 29, 2010 | Samsung 933HD 19 in. LCD TV
    How remove the Sony Rear Projection TV KDS-R50XBR1
    the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
    Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
    Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
    1. Disconnect all cables.
    2. Cover a level and stable surface with a thick and soft cloth.
    3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
    4. Rotate the cable holder 90 degrees, and pull it out completely.
    5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
    6. Do not remove any other screws from the TV.
    They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
    Hope this helps!
    Thanks
    Smith.
    Sep 07, 2009 | Televison & Video
    Remove base of Insignia ns-ltdvd26-09
    to remove base from insignia tv
    1)remove plastic cover from bottom rear of tv
    2)remove 8 philips head screws on rear of tv above base
    3)pick up tv and base will come off
    once you remove it you realize how easy it is
    Jun 29, 2008 | Insignia LCDTV26 26 in. Television
    Remove base from television
    Remove 2 screws on the back bottom by the stand.
    Remove 4 screws, two on each side about 3/4 of the way toward each edge.
    Pull TV up to remove from stand. Put plate and 2 screws back.
    Can see this if you download the manual from the hitachi site. Just do a search for the model no. on their site's search engine.
    Mar 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
    How to remove stand
    Just taken the stand off my LG 42LC2D. The stand is made of cast aluminum and has 2 long legs that insert into the base of the TV. So to remove the stand lay the TV on its screen and remove the two screws that are vertically in line next to the power socket the the 2 screws that are vertically in line under the RGB socket. The stand then pulls out from the bottom of the TV.
    Dec 16, 2007 | LG 42LC2D 42 in. LCD HDTV
    Remove stand from LG 50PC5D
    There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.974336c.png
    Oct 16, 2007 | Televison & Video
    Televison & Video Logo
    141 people viewed this question
    Top Televison & Video Experts
