Question about Sony KDL-32M3000 32 in. LCD Television
My Sony KDL-32M3000 has dark reddish picture, checked the ribbons around the frame they're ok, power supply is ok, Hi voltage board is ok, I'm guessing the main video processing board since I don't have a service manual can't find the faulty component, any help is greatly appreciated. Sam
    Problem Solver:
  • 12 Answers
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Posted on Jan 10, 2011
  • 1 more comment
  • Domingo Mendoza Jan 28, 2011
    Check Tcon board (between BM board and LCD Panel. It is located in top center area of LCD Back Side. In Tcon board, there is a small fuse with a P printed in its body, near connector base which comes from BM board. Check if it is open or not. Mine was open and replace it with good results, now picture is back.
  • ewoldtc Mar 25, 2011
    I have the same problem Tcon fuse "p" F1 is open. Does anyone have a part number for this fuse? Thanks
  • Cowa Bunga
    Cowa Bunga Apr 04, 2019
    Same problem here, F1 fuse on the T-con board is open. I soldered a wire across the fuse, and now my picture is back.
SOURCE:
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
Dec 30, 2012 | Sony KDL-32M3000 32 in. LCD Television
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony KDL-32M3000 LCD TV.. When I turn the tv on you can see the screen lite up with no kind of picture, Almost like a lite comes on then goes out the the lite comes on again with no picture but I...
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!@#
Mar 25, 2011 | Sony KDL-32M3000 32 in. LCD Television
Dark screen
How do I Calibrate a Sony KDL-32m3000 LCD TV? By Oliver Hill, eHow Contributor updated: October 2, 2010 do-sony-kdl_40v2500-lcd-tv_-200x200.jpg Calibrating your Sony HDTV will give you the best settings available for your TV. Fotolia.com">tv control and tv 16 image by chrisharvey from Fotolia.com
People often calibrate their TVs to give themselves and their family the best possible viewing pleasure. Using the optimal settings on your Sony HDTV will give you an overall picture and sound quality that is the very best that your TV can offer. If you are yet to effectively calibrate your Sony TV you could be only getting a small amount of what your TV can offer you.
Difficulty: Moderately Easy Instructions Things You
Jan 18, 2011 | Sony KDL-32M3000 32 in. LCD Television
Screen dark but can still see picture
could be a problem with the inverter board which is the power board for the CCFL backlight system. if the tv doesnt actually go into shutdown you may be able to still see the video but it will be very dark no glow to the screen at all. the reasons for shutdown for inverter failure could be a bad inverter transformer or open fuse on the inverter that supplies power to the board or it could even be a bad CCFL lamp. i suggest looking for the fuse that is the most likely suspect it may be yellow if i remember correctly. good luck
I have a sony 32m3000 color is dark and red also
@circuitworld: You claim in your profile that you repair plasma and LCD TV's, but you just told someone with an LCD to replace the convergence IC's and linear buffers. First off, convergence IC's are in rear projection TV's not LCD's, and the buffer boards are in plasma's, again, not in LCD's
@gardenwc: Typically what you are experiencing is a bad video controller or an actual faulty panel, the latter of which is not cost effective to replace.
Nov 03, 2009 | Sony KDL-32M3000 32 in. LCD Television
Kdl 32m3000 we have changed 3 boards on this
That's correct it is the LCD panel. This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprising long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
Jul 01, 2009 | Sony Televison & Video
White lines slow movement
panel is starting to seperate. usually covered under manufactureer warranty. wait m3000 is older model. then its usually not recomened to replace panel not very economical.
Jun 03, 2009 | Sony KDL-32M3000 32 in. LCD Television
Sony KDL-32M3000 32 in. LCD Television Logo
655 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
