Samsung YPT9 Digital Media Player Logo
Posted on Dec 25, 2010
Necesito el firmware para yp-t9j no enciende de ninguna manera lo unico que aparece es el logo samsung y se apaga
5 Related Answers
Anonymous
  • Posted on Jun 29, 2008
SOURCE: Samsung YP-T9J Mp3 player freezing up
all you have to do is hold the menu and a-b button at the time for a few seconds and it goes away
Anonymous
  • Posted on Aug 03, 2008
SOURCE: YP-T9J Screen stuck on transferring files do not disconnect
Vegggie Boy is mistaken. You should press and hold the red record button while pressing the menu button. The player will reset itself to normal operational mode.
Anonymous
  • Posted on Sep 24, 2008
SOURCE: Samsung YP-T9j won't turn OFF - Automatic Test Mode
How do i reboot and delete everything off
Anonymous
  • Posted on Jan 17, 2009
SOURCE: software for yp-t9j
I LOST MY CD SOFTWAER
Anonymous
  • Posted on Jul 25, 2009
SOURCE: i want to completely reset my samsung yp t9j
Yes there is a way and it worked for me... If you have windows media player than you can empty you samsung t9... All you have to do is plug in your samsung and it will say on windows media player (left) samsung... right click the word samsung and it will give you options.... than click fromat and it will delet everything....
Hope this worked for you because it worked for me.... IF it worked than give me a thumbs up... thank you
Tengo una Lincoln Mkx 2007 con 69900km y al girar el switch con su llave adecuada prende el candado y se apaga intermitente y da un pitido de aviso bajo el tablero y no enciende regreso el switch a...
Puede ser un modulo que esta malo eso es lo mejor llevar lo al dealer para que lo chequen.
Mira ver si lo puedes llevar a advance auto parts para que te chequen el alternador puede ser que esta mandando mucho voltaje a lo modulos y causa que el systema se apague.
Como desbloquear regiones al blu ray
Hola soy de M?xico y tambi?n tuve el mismo problema mucho tiempo hasta que encontr? la soluci?n y aqu? te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ning?n disco en la bandeja.
2. Apaga el reproductor y vuelve a encenderlo (Esto es necesario para limpiar-arrancar el firmware)
3. Espera hasta que la p?gina del men? principal aparece y el reproductor ya no haga nada.
4. Pulsa el bot?n de expulsi?n para abrir la bandeja.
5. Pulsa el bot?n de expulsi?n para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado num?rico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El c?digo de regi?n "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la regi?n free.
8. Apaga y enciende de nuevo el reproductor.
9. Disfruta de tus pel?culas :D :D :D
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE.
Region code
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucion y aqui te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ningun disco en la bandeja.
3. Espera hasta que la pagina del menu principal aparece y el reproductor ya no haga nada.
4. Pulsa el boton de expulsion para abrir la bandeja.
5. Pulsa el boton de expulsion para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado numerico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El codigo de region "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la region free.
9. Disfruta de tus peliculas :D :D :D
Hello, recently purchased a Samsung BD-E5900, would it be possible to make it a region free player?
How to unlock Samsung BD-E5900
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucien y aqui te dejo paso a paso como hacerlo ;)
I have a samsung bde 5900 bluray player. Can someone help me unlock the region code?
NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE..
2helpful
2answers
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
5helpful
2answers
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
2answers
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
