Question about Whirlpool LGR7646E Dryer
Dryer is running but it's not hot
Our Whirlpool LGR7646E Dryer is using electric power to run and the heat is coming from gas.
When I press "Start" button it runs but no heat comes out. Why?
Can you please help me?
Thanks,
Silvia
  • 3 more comments
  • ys99lee Jul 07, 2008
    I am afraid that my electronic start to ignite the gas is not working. If so, how to fix it?
    Thanks,
    Silvia
  • Anonymous Jan 21, 2009
    i have same prob and tech guy said to pop the front panel and check the ignitor,,,, how do you pop the panel ? i popped the top but the front feels like im ganna break something....
  • machnik1869 Mar 16, 2009
    dryer runs but no heat. don't hear a poping soundor gas hiss.
  • Kirk Severs
    Kirk Severs May 11, 2010
    do you hear a popping sound when you hit the 'start' button? Can you hear the hiss of gas flowing?
  • Kirk Severs
    It sounds like your electronic start to ignite your gas is not working, or your gas is not flowing to the burners to ignite. Do you hear a popping sound when you hit the 'start' button? Can you hear the his of gas flowing?
EVERYTHING IS WORKING FINE IT JUST WON'T HEAT. IT DOES NOT SOUND LIKE IT IS IGNITING
Posted on Apr 01, 2009
    Scholar:
  • 170 Answers
If the electronic start is not working, it may need to be replaced. Call an appliance parts store and ask some specific questions to them about how you can test that component and if they carry a replacement for your specific make and model. Good Luck!
Posted on Jul 09, 2008
Whirlpool dryer: Running but hot air stops coming.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool supreme gas dryer will not heat up. model# LGR7646EQ3
heatman101
Aug 17, 2010 | Whirlpool LGR7646E Dryer
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
LGR7646E Dryer: is not heating up...
heatman101
May 18, 2010 | Whirlpool LGR7646E Dryer
WHIRLPOOL DRYER GGQ9800LWO NOT HEATING UP
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Apr 21, 2009 | Whirlpool LGR7646E Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Initial gas burn does not reignite
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Dryer no heat but runs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Spins but no heat
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
273 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
