Question about Lexmark Office Equipment & Supplies
When printer is set up to print, it makes a brief knocking sound and on little screen at top it says...unlock scanner
    Scholar:
  • 135 Answers
If the printer LCD screen continues to display the same error message, do the following:
Remove both cartridges from the printer.
Move the red lock switch (at the back of the printer) from the down position to the up position, and then move it back to the down position.
Unplug the printer and turn it onto its left side.
Then return the printer to the upright position and reapply the power supply.
Attempt this fix twice and then try to print and scan once more.
note : Installing the wrong upgrade file will not cause damage to the printer, but the LCD display will display some characters incorrectly. Downloading and installing the correct firmware will resolve this issue
Posted on Jul 05, 2008
Printer will not print a test page and makes a soft clicking sound instead
Brief:open left, right, top covers., remove laser scanner assembly., remove protected cover., u can observe that, a movable shutter ment for stops the laser beam., remove it., fix all back.. chk...
Sep 12, 2014 | HP LaserJet P1505n Printer
Print result sideways
It sounds like your printer is set to print landscape, instead of portrait mode. Next time you want to print, click on file(top left of screen), then print (don't just click on the little printer icon). This will open a new printer window where you can choose different setting. The option to change from landscape to portrait will be listed somewhere in that window. Once you have selected that feature and print it will stay that way unless you change it. You will have to check this setting in each computer program you use.
Jan 23, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Screen saying scanner error
You can try uninstall and install printer driver or try a known good connectivity cable.
Dec 13, 2012 | Canon MX310 Office All-In-One Printer
Canon d320 image class makes knocking sound and nothing prints
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section
pifonski
Feb 20, 2011 | Canon imageCLASS D320 Digital Copier
Powers down after every print
There is a setting in the all CPCL based Zebra mobile printers called "DTR Power Off". You will need to turn disable this. It sounds like you are printing through the serial connection based on your brief issue description.
Connect to the printer with serial cable and run the Label Vista application, free from Zebra.com. If your printer is a Q3C or Q3D configuration, you can connect with a mini USB cable, but you will have to install the driver. If you have a Q3A or Q3B configuration, you must to use the serial cable (PN: BL11757-001) to connect to your PC.
Once in Lavel Vista, click on the Printer drop down and choose the COMM Port Settings option. Select the correct value for your connection type. Next, select Printer Settings from the Printer drop down. Go over to the Port tab and click the disable button under the DTR Power Off section. Click apply. If this does not work, also check your inactivity timeout setting as well as your battery level setting in the batery tab od the same screen. I set mine to "0" because I dont want my printer turing itself off for any reason.
Apr 04, 2009 | Zebra QL320-Plus Mobile Printers QL320...
Scanner failure is holding up the whole printer
Sorry, a common HP printer problem....uneconomical to repair.
Jan 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Samsung "scanner locked"
I went through the same thing! It drove me nuts, and I even calls CS, which is great by the way. The sweet girl on the other line couldn't figure it out, but I finally Googled it.
In the opening where the printed pages come out, if you put your hand in there, on the top left is a lever.
This is the scanner lock. Once you flip the lever and hit the stop/clear button, it should be all better. At least that is what worked for me!
Nov 06, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanner error on screen
Turn off printer, open scanner cover. On the right handside of scanner glass there is a switch in which you can toggle to lock and unlock position. toggle it 3x and set it to unlock. turn on printer. you should be able to make use of printer now..
Feb 07, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Samsung CLX-3160FN "scanner locked"
Every Samsung multifunctional device has a scanner lock underneath the glass. This is to prevent scanner damage during shipment. Th user's manual in the CD and the unpacking sheet clearly illustrate where this lock is. If you open the top lid and look to the lower left corner of the glass, you will see a small lock-open/lock-closed symbol. Underneath that symbol you will find the lock. I'm including a small visual reference of a similar model. Just remember to turn off and on the unit after the lock is removed.
Sep 28, 2007 | Samsung CLX 3160fn All-In-One Printer
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
