Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Green tint My jvc av48wp55 has a green tint everything else is working fine. Can not adjust the green tint out.
  • 2 more comments
  • 06Goatman Jul 05, 2008
    already have the service manual, which is no help. I do know how to adjust thru menu but can not get the green tint out. As if there is no true black. The screen looks like you are looking thru a green film.
  • 06Goatman Jul 06, 2008
    green tint no matter how adjust. If a cover the green lamp with a thin cloth takes out the green tint. But of course makes it hard to get the colors right. But it is alot more watchable. How to adjust the brightness of the green lamp? Because the controls on the menu do not affect the green.
  • 06Goatman Jul 09, 2008
    No all connections are tight. Still have the problem with the green tint.
  • 06Goatman Jul 13, 2008
    When I use the tint feature in the menu it has no affect no matter how much you adjust. Probably cheaper to get new tv. Tried everything else nothing helps.
  • JVC Master
  • 19,396 Answers
You simply need to replace lamp, it is a common problem, red lamp has gone.
Here you find manuals:
JVC Projection HDTV manuals
Posted on Jul 13, 2008
    Genius:
  • 1,226 Answers
The most common fault in this is the connection in the projection. maybe had it loss or some part of it got busted.
If you can self tech the TV, i recommend you to check the vertical and the horizontal projection of the TV. Or adjust inside the tint if it is not an auto adjust. if it is auto adjust then concluded that parts is loss connection or busted parts.
However the most effective way is consult the vendor or the service center of your TV.
melnavz
Posted on Jul 09, 2008
  • Emelio Navaja
    Emelio Navaja Jul 15, 2008
    consult the vendor of your TV. This is the best way so far.
    Master:
  • 497 Answers
Http://myhometheater.homestead.com/VideoBasics2.html
this link would explain to u ur problem even though it wont help in fixing it..i hope the other solutions would enable you to fix your problem
Thanks for using Fixya
  • 983 Answers
The CRT tube is in problem ....
you must replace the CRT tube ........
check whether any interference is happening ....
interference happens if you have some magnetic field near by the tv just like some speakers , telephone line etc ....
just have a check with the interference otherwise it is confirmed that CRT tube is in problem ...
you can recharge the same CRT tube but you will not get so much performance & clarity as earlier so it is better you replace the CRT tube ....
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 09, 2008
    if there is reset option then try giving reset once ....
    if the CRT tube goes weak means you will be facing this kind of discoloration problems ....
  • 4,889 Answers
It is a convegence related issue. Either the projection convergence settings are not correct or the Convergence IC is gonna take a break. If you are sure that the settings are all right then i will put my money on the convergence IC. The service manual should specify something about convergence Ic and what should be the voltage that should flow across it. Get a multimeter and check this. I can get you a replacement provided you tell me the part number..
Let me know how it went so that we can follow up on this..
Posted on Jul 06, 2008
  • eagle338
    eagle338 Jul 09, 2008
    For Resolving color related issues here is how you can adjust the amount of different colours.
    http://www.somelifeblog.com/2007/06/sony...
  • eagle338
    Like the blog suggested just turn the green adjustment a little. But beware this is a high voltage repair and you should exercise extreme caution. Do not touch the components with hands. Also to be sure you are safe wear tennis shoes to minimize the risk of electric-shock.
    Guru:
  • 1,342 Answers
If you are using component video cables check them first. You might have one that isn't pushed on all the way.
Posted on Jul 05, 2008
  • 2,071 Answers
Posted: Wed Jul 18, 2007 5:50 am Post subject: JVC Service Menu Codes - Plasma, LCD, CRT, RPTV green tint - icon_quote.gif NOTICE: MUST READ BEFORE USING SERVICE CODES!!!
this information for those that are qualifiedand trained to do TV repair work. Entering or making changes in servicemode by untrained persons can cause significant and permanent damage toyour television. If you are not qualified to service your television,please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
    Master:
  • 848 Answers
Try this
Disconnect the filament - all evidence of a picture, raster, and retrace lines should disappear once the filaments/cathodes have cooled (15 seconds or so. If there are still visible retrace lines, the CRT is suffering from cold or field emission from someplace (may not even be the cathode).
Turn down the screen (G2) control on the flyback (usually). If one color remains no matter how you set the control, again there is some kind of weird emission from the CRT. However, if white/gray retrace lines remain, the problem may be in the screen supply.
  • gopinath pasupathy Jul 11, 2008
    better take to service center to get your problem solved .....your problem looks very much complicated
    Genius:
  • 1,665 Answers
Green tint
might be adjusted in the tech menu but I recall this set having early on a few odd issues--wrong color, lettering backwards or upside down etc---there was a software upgrade for those---you might want call JVC
Apr 02, 2012 | JVC HD-56G886 56" Rear Projection HDTV
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Apr 01, 2012 | JVC HD-56FN97 56" Television
Have a 27 " JVC
Hi ,
welcome to Fixya, it sounds like you may have a weak CRT (picture tube)
If the TV is over 6 years old that may be the case.
There are RED, Blue and Green color balance adjustments that you can try .
referencing the exact model one could see how it adjusts.
hope this helps
Roety
Mar 11, 2011 | Televison & Video
I have a JVC model AV27320 standard TV. The picture is dark and the tint is off. The colors you can see are blue and red. Tried adjusting tint and brightness from the menu and no significant change. ...
It is one of two things the picture tube is bad and the green emission is very low or the green gun is open, the second possibility is the video driver or output is shorted on the video board "plugged in the back of the picture tube"
Mar 03, 2011 | JVC Televison & Video
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Green Tint On Xbox Monopoly Game
have you tested with another game?
maybe you are running a EURO game...the colors go crazy....it´s normal...try a usa version...
Dec 05, 2008 | Microsoft Xbox 360 Console
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
141 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
