My sharper image MP3 isnt charging.
I have plugged in my mp3 player to the charger and it keeps saying battery low and then it shuts off. i have tried to charge it while its off and on. but no matter which way i charge it its still not working. There isnt a battery in side of it either.
  • 8,596 Answers
Make sure the firmware is up to date
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
Wen i turn it on it says battery too low system shut down but wen i plug it in too charge it dosnt charge up it just says the same thing
Possible that the battery can be bad, so to confirm first check the charger adapter of the player and see if the voltage is good. If so let the player shuts down with the power fully OFF.
The set the charger ON for a full day and check the player to play. If the player fails then it is possible that the battery is faulty.
Try to open and check to confirm before you can replace.
Dec 30, 2010 | SanDisk Sansa e200 MP3 Player
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Sharper Image MP4 Touch Player (NEW) not charging
Mine looked like that, however, it has 2 "on" buttons. The major one on the left. says on off. Put to on. Then the upper button on the right, is actually the on off/ push and hold for 3 sec. then wait, it should come right on.
Apr 03, 2010 | Sharper Image 1612911 MP3 Player
When i plug my walkman up to the usb charger it says low battery please charge but it dosent charge
It may not seem it, but it actually is charging - it's just frozen. Keep it plugged in for a few minutes, and then look for the small "Reset" button on the bottom left corner of your mp3 player. You're going to need something very small to get at it (like a pin or sewing needle). That should fix your problem.
Dec 24, 2009 | Sony Walkman NWZ-S616F MP3 Player
My mp3 player wont turn on, its frozen or something
Maybe the battery is dead, try to use a diiferent battery or charge it. You might as well try to clean the battery terminals just to make sure it's not just a loose contacts.
Oct 22, 2009 | Sharper Image 1612911 MP3 Player
Creative zen battery indicator problem
Try to reset it. May be it stuck. On my Creative Zen Vision M I do reset by inserting a paper clip into a small hole near a dock connector. Good luck!
Sep 09, 2009 | Creative Labs Zen Touch MP3 Player
Only works when plugged into power source
The battery will charge when running from mains. If you leave it plugged in for 20 minutes and then unplug, use and note how long before it shuts off, recharge again for 40 minutes and repeat.It shuould last a lot longer after a 40 min charge. And if it only lasts a minute or so after the first charge then the battery needs replacing (sometimes it's cheaper to replace the player) if it doesn't work at alll after 20min charge then definatly battery gone.
Jun 02, 2009 | Sharper Image 1612911 MP3 Player
My rca m4208 mp3 player wont turn on
i juat keep it on the charger to charge and it works again
Jan 10, 2009 | RCA M4208 MP3 Player
Will not charge
If the battery is dead as in not recoverable you may get this problem .
You could try another 5v charger in case yours is Duff
Phillips have responded well in the past so a visit to their site may help
Oct 19, 2007 | Philips HDD120 MP3 Player
63 people viewed this question
 Grubhead
Grubhead
