Question about RCA D52W19 52" Rear Projection Television
Tv problem I have a 52' RCA box style since 1996. No trouble before..it has sound no picture..about 2wks ago the picture popped on it showed double vision like a little pink in color..so i cut the tv off and the picture was perfect..please help it possible..i really would not like to buy a new tv set if possible..i do have cable called U-Verse from AT&T it is fiber opted...
    Sergeant:
  • 233 Answers
It sounds like your convergence is going bad.. this is pricey in older tv's. Look inside (but be careful) and see if there are some really big heatsinks with a IC mounted on each one. they should have a number like STK???-???. These are the convergence IC'S- change them, and you should be ok (IF your set uses the STK style IC's)
hope this helps.
Posted on Jul 15, 2008
52 " RCA led flat screen TV doesn't have a picture anymore. Sound works but no picture. I heard a pop and then no picture. TV is only 2 years old. It's an
Sounds like it time for a new one by the time you have it looked at and repaired your better offer just to buy a new on sale
Feb 24, 2016 | RCA Televison & Video
Tip
Tv picture has a bow in it and letters are doubled my 52" rca just started the...
I ALSO HAVE A 52 INCH RCA (2 YEARS OLD) I HAVE TRIED ALL OF THE TIPS THAT HAVE BEEN DISCUSSED. LUCKILY I PURCHASED THE EXTENDED WARRANTY ON THIS UNIT.. AFTER A MONTH OF OVER THE PHONE TROUBLE SHOOTING FROM WARRANTY REPAIR CENTER THIS INCLUDED REMOVING THE BATTERIES IN CASE THE REMOTE WAS BAD. THEY FINALLY CAME AFTER IT YESTERDAY. THE PICKUP BOYS SAID THAT THEY ARE HAVING A LOT OF TROUBLE WITH THESE UNITS DOING THIS SAME THING. THEY ALSO SAID THAT SOME WERE BEING REPLACED WITH NEW ONES. NOT SURE IF RCA OR WARRANTY IS REPLACING (MINE WAS PURCHASED FROM BESTBUY WITH BEST BUY WARRANTY). IF ANYONE HAS SPOKEN TO ANYONE ABOUT A REPLACEMENT PLEASE RESPOND. I THINK IF THERE ARE SOME UNITS BEING REPLACED WITH NEW ONES WE ARE MORE THAN LIKELY GETTING THE SAME DEFECTIVE UNITS (WHICH WILL MORE THAN LIKELY WORK UNTIL OUT OF WARRANTY). I WISH THEY WOULD JUST GIVE REFUNDS OR CERTIFICATES TOWARDS NEW DIFFERENT UNITS MAYBE IF THERE WERE ENOUGH COMPLAINTS THIS MIGHT BE CONSIDERED.
on Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
When i turn on the tv 52" rca rear projection the power light goes on and off but it does not turn on.it takes everal attempts before i get picture and sound
Does it make a slight popping or cracking sound ? If so remove the back cover and see if the flyback transformer shows any sign of burning or arcing. It is located on the far rt. hand rear side with a red wire comming out of the top and a black one behind and lower than the red one.
Oct 13, 2009 | RCA D52W19 52" Rear Projection Television
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture convergence and double lettering
there is a bad dioded rca part # rca 259638 its in the convergence part of the tv it has to be replaced
Aug 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
