Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer making squeaking noise
Describe your problem How do we disassemble or open panel to look inside. Does the back come off or the front of dryer?
    Scholar:
  • 170 Answers
Usually there's a kick plate or panel at very bottom front of dryer. Take that off, then you can take the front off and then the top to look inside.
Posted on Jul 05, 2008
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
Dryer works fine but squeaks
on most dryers this indicates the need to replace the glides and (or) bearing socket
If you look inside the drum and see 3 screws at the back of the drum then it
most likely is a bearing socket, I usually replace the front glides and felt assembly
as well (total for the parts is around 40 dollars). It is rather difficult as you must disassemble\
the whole front of the dryer to install the glides and socket. If you choose to do this
use spring clamps to hold the felts as the glue dries overnight this makes reassembly
much easier. Usually there are two springs which must be pushed back between
the lid and front to access the bolts holding the front panel on. You may want to look
up a parts diagram before attempting disassembly and remember to shut off breakers
and unplug unit before servicing.
May 04, 2011 | Kitchen Ranges
I have a ge profile 2006 front loader dryer that is making an awful squeaking noise!!
It will be your back bearing or front glider pads that are bad you will need a qualified service technician to come out to repair it unless its eating thru the metal on the inside then its not worth fixing sorry for the trouble and good luck. You can check the front pads by open the dryer door looking on the inside of the dryer towards the top front and see if it is resting on the plastic clip or metal that will tell you if its the fron or back.
Jan 06, 2011 | Dryers
Dryer squeaks like crazy.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
GE Dryer Model DWSR483EA1WW squeaky noises
Un-plug dryer. Remove screws from front panel into dryer top. (just inside the door, at the top of the opening) Swing top up and remove screw near top of front panel on each side. Tilt front panel forward and lift off, set to the side. (leave wires attatched) Pull drum ahead about 4 inches. Do not remove belt. (it's a little tough to get the drum past the sides of the dryer) Remove the old rear drum bearing and replace it. If I remember correctly, it is a part number WE3X37. Replace drum. Check the front drum support slides on the front panel. They should be about 1/8 inch thick. If the rear bearing was squeaking, they may need replacing also. Finish re-assembly, plug back in and test.
Oct 18, 2009 | Dryers
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
IF YOU CANNOT SEE AN OBVIOUS WAY TO OPEN THIS, SUCH AS SCREWS AT THE VERY BOTTOM OF THE FRONT PANEL OR AT THE TOP OF THE DOOR INNER RIM OR BY REMOVING A BACK PANEL 2'X2' THEN CHANCES ARE THAT THE TOP WILL POP UP AT THE EDGES IN FRONT BETWEEN THE TOP AND FRONT PANEL. FROM THERE LOOK INSIDE THE FRONT PANEL AND SEE IF THERE ARE A HEX HEAD SCREW OH ABOUT 3 INCHES DOWN HOLDING THE FRONT TO THE CABINET IF THERE IS REMOVE THEM AND DOOR SWITCH WIRES AND LIFT FRONT PANEL UP AND OUT. WITHOUT THE MODEL NUMBER THIS AN EDUCATED GUESS. IF I WAS RIGHT FROM THERE I THINK YOU CAN GO THE REST OF THE WAY AND THE SQUEAING NOISY SHOULD BE THE BEARING IN THE REAR OR THE DRUM ROLLERS. GOODLUCK TO YA
Apr 12, 2009 | Dryers
Dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Nov 18, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
149 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
