Question about Princeton Digital VL1916 19" LCD Monitor
Princeton Monitor Hi, Did you ever fix your Princeton monitor? I am having the exact same problem! Any advice? thanks, Steve
  • 59 Answers
There is a field of capacitors on the power board that usually goes bad. I believe that there is a total of 6. When you look at the power board you should notice them. I have the capacitors if you need them. $2 each. Just check to confirm that they are swollen. and let me know the voltage and uF. good Luck. David
Posted on May 27, 2009
tantong
  • 138 Answers
SOURCE: Princeton Monitor VL1917 - No Power
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 20 Answers
SOURCE: will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Posted on Mar 27, 2008
skotkolr
  • 558 Answers
SOURCE: I have two CTX monitors.
well by ordering the caps replaced that is a start for the first one it should work like new when you get those replaced, second monitor it could still be a cap issue but you need to look and see if they are doomed if hey are popped then they need to be replaced, one of the reasons they shut down is variance in the power supplied to the ccfl if it variances too much the unit shuts the vga and thereby the ccfl unit off.
fyi you don't need all the caps replaced just the popped ones.
Posted on Apr 30, 2008
  • 4090 Answers
SOURCE: Hi Team, I have Dell Ultra Sharp Monitor which
If you are not an electronics tech It would be remiss to advise you to interfere with a high tension device like a monitor. take it to where it can be serviced and keep your life. Only experienced people should open up a monitor and poke around 22000 volts is involved here and if its overheating the wiring on th ecoilod ids breaking doen or has broken down.
Posted on Aug 01, 2009
budmrtn
  • 11361 Answers
SOURCE: i have the princeton VL193 monitor. Its blank, no power light
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Testimonial: "thank you the explanation sounds like its right on the mark. Unfortunately, I see these being sold used for under $50 so it is not worthwhile for me to repair as I don't have the expertise and I would think I would be charged at least that by a shop.I was hoping there was a reset button as I think the monitor succumb to an outage. Thanks again. "
I get an error message regarding monitor resolution settings
It wants you to set your PC video resolution to the native resolution of this monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 27, 2011 | Princeton Digital VL173 Monitor
My Princeton Monitor VL2018W does not have sharp colors.
I fixed many of these, look for bad caps.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Make sure to replace the whole set on the low DC power supply side with good caps, not from Radio Shack standard electrolytic type.
Panasonic caps from DIGIKEY
http://dkc3.digikey.com/PDF/US2010/P1648.pdf FM series
http://dkc3.digikey.com/PDF/US2010/P1645.pdf FC series
http://dkc3.digikey.com/PDF/US2010/P1646.pdf FC series
Jul 10, 2010 | Princeton Digital VL2018W Monitor
I have a Princeton VL173 Monitor and when I switch it on the screen comes up for about 2 seconds then goes blank,and each time I switch it on and off by the monitor it only stays up for a second or two. I...
Would think that this one could be a bad capacitor problem.
The unit is pretty easy to dissasemble, and remove the screen itself from the housing, look at the power board, the main board in the middle of the unit, and see if you see any bulged or leaking capacitors. they look like little beer cans...should be flat on top. If you see any bulged or leaking capacitors, order replacements at mouser.com and replace them with a soldering iron. Should fix the problem. Bad caps are a very common problem in all kinds of electronics.
Dec 31, 2009 | Princeton Digital VL173 Monitor
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
Aug 03, 2009 | Princeton Digital VL2018W Monitor
Princeton monitor, model # vl1916 Wont power on.
Hi, Billman11, maybe you can repair or maybe not. You need to tell me some stuff first. Need the approx age of the display. Next thing! Does the monitor have external power supply? (black box, sit on floor type) or internal (line cord to wall outlet, and other end to monitor) What exactly happens if monitor is connected to afully booted PC with known good vga output and u connect the flat screen lcd and push the power button? Is lcd panel still pitch black? no flicker or anything? Can you see the power on led indicator even?? From waht you already described it sounds like a Switch-Mode-Power-Supply failure. Each lcd monitor has 2 or 3 printed circuits inside under metal shields beneath the black plastic case covers. In your case, we will want to investigate the board that the line cord plugs into. That will be the smps board, or the little black box on the floor. If you want to try fixing this monitor you can get back to me at louie12fix on fixya or lmistyrel@ aol.com Yes, I'm a vet and spent a year on Kanghwa Do, Korea 67-68 Work for company that provides electronic hardware/software to the gaming industry and located northern Illinois. BYE for now.
Mar 31, 2009 | Princeton Digital VL1916 19" LCD Monitor
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
Prinston VL2018W Nothen but White light, when signal is present.
Steve, do you want to sell that monitor? I need the screen for one of my princetons.
if you do, email me at Yeawellbutyaknow@aol.com
May 16, 2008 | Princeton Digital VL2018W Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
82 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
