Question about Cisco Catalyst 2924-XL Enterprise Edition Networking Switch
Cisco catalyst 3500xl (24 port) bad console
I have a 3500 xl and the console port doesnt work. The LED's indicate that the switch is booting up and working.
I have moved laptop and console cable (rollover) from this switch to another and it works. So the console port on this one is not working.
How do I find a schematic or something that indicates how I can bypass or workaround this.
Thanks
  • hendrasaat May 24, 2009
    can't connect console catalyst 3500,is there firmware software that can reset to factory default?
  • 55 Answers
It is possible that your console port is configured for a different baud rate. Try to change your baud rate on your hyper terminal going from 115200 down to 2400. If it doesn't work you might have a problem with 232 driver chip that is located on the board next to your console port. You will not be able to find a schematics for this switch, it is not available for the public.
You can send this switch to me. I will glad to fix it for you.
Good luck.
336-416-1802
NetSalem
Posted on Jul 17, 2008
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco 3524 not receiving vlan info
Try this http://tools.cisco.com/search/results/display?url=http%3a%2f%2fwww.cisco.com%2fc%2fdam%2fen%2fus%2fproducts%2fcollateral%2fswitches%2fnexus-4000-series-switches%2f6701_catswitch_guide_v7_r5.pdf&pos=5&query=WS-C3524-XL-EN
Mar 08, 2014 | Cisco Catalyst® WS-C3524-XL-EN 24-Port...
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
HAVE 24 PORT CISCO CATALYST 2960 SERIES SI ,HOW TO PUT IT BACK TO FACTORY SETING SO I CAN USE ALL 24 PORTS WITHOUT MANAGE..???
Due to the length of the solution I have provided you with a link to the Cisco site on how to reset catalyst switches.
It is not a simple process and you need to read the instructions carefully.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Dec 15, 2010 | Compaq Cisco Catalyst 296024S switch 24...
Console interface problem on the switch
HyperTerminal sucks. Use PuTTY and make sure you have the correct baud rate of 9600 set.
Putty Link:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 30, 2010 | Cisco Catalyst 3550-24 24-Port Ethernet...
Can't console cisco catalyst 3500
It's possible that the management port is on another VLAN or is not enabled. Your most reliable bet is to try a serial connection to console in.
Alternatively, there is a procedure that will work even if you don't know the password:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swtrbl.html#wp1028958
Jul 15, 2009 | Cisco Catalyst 2924-XL Enterprise Edition...
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Default pasword
Cisco switches dont have a default password.
You will have to perform a password recovery process that is quite extensive.
You need to console into the switch using hyperterminal or teraterm and follow these instructions located at: http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Dec 13, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
Cisco 2801
What Model Series do you have?
Nov 11, 2008 | Cisco Catalyst 2924 Networking Switch
Cisco Catalyst 2924-XL Enterprise Edition Networking Switch Logo
1,321 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
