Recording from audio tape to laptop
I have a TEAC stereo cassette deck R-H100.
I have got an audio tape I would like to transfer to my DELL Inspiron 6400 laptop.
What is the procedure?
In particular, are there limitations in terms of R-H100 line out vs. laptop microphone line in voltage specifications?
I couldn't find these specifications for any of the 2 products.
Thanks for your help!
Best;
Vincent
  • 1,512 Answers
Hi Vincent.
Just use the play out connections on the back ot the deck, and connect them straight to the line in socket on the lappy. Use a RCA stereo to 3.5mm stereo jack connection, levels will be fine. Try audacity as a decent freeware recording program. Woks well, and you can use half decent plugins to tweak the audio. :)
regards
robotek
Posted on Jul 08, 2008
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
No sound or recording to computer
You need a program to interface between the tape deck and your computer. Try Audacity. It's free.
Feb 22, 2015 | Pyle PT659DU Dual Stereo Cassette Deck...
Record button wont press down
Record button can be pressed down only if you placed a cassette into the deck and if this cassette was not protected against recording. This protection is mechanical, and can be found at the top of the cassette. One for the A-side and another one for B-side.
Thanks,
gylacz
Feb 01, 2014 | Teac W-505R Single Dual Cassette Deck
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
My Sony dual tape deck does not record in stereo anymore.
Oxide deposits on heads can restrict audio transfer to tape. You may need to do a deep cleaning of record head. Depending on how much deposits are on heads may need no more than alchohol and Q-tip. Be sure to clean erase head and drive roller. Afterwards, try recording, then use headphones in jack on recorder to check for recording on both channels. If this works, problem is not in rest of equipment set up. If you still need help, email me
Apr 21, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
110 people viewed this question
 Grubhead
Grubhead
