The lcd monitor does not have a picture and will not shut off when it has power.
    Novelist:
  • 183 Answers
§ Turn Off the Monitor.
§ Unplug all the Cables from the back of the Monitor.
§ After unplugging all the Cables press and Hold the Power Button at the Front of the Monitor for 20 Seconds.
§ Plug all the cables back.
§ Turn it on.
§ See if you get the Picture on the Monitor.
§ if you don’t get any Picture then.
§ Unplug the Cable which is connected at the Back of the CPU.
§ If you get the Message "No Input Signal” or "Check Video Signal" it means that Your Monitor is Fine.
§ Try doing the Factory Default settings from the menu Buttons at the Front of the Monitor.
§ If you don’t get any Message then it means you Monitor has Gone Bad and Needs to be replaced.
Posted on Jul 05, 2008
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Screen goes dark after 1minute, power lite stays on
Possibly the lcd ccfl inverter. Ebay sells universal ones for 9 to 25 dollars each. Monitor repair knowledge needed to replace this part.
It could also be your external power supply if it is not OEM. Or if it failing under a load. If the picture is good when it is on, I always start looking at the power supply and the ccfl inverter/transformer. Please understand I am not an expert on LCD's I just seem to get lots of failing ones. ---Hope this helps.
Jul 25, 2010 | X2Gen MG19MY 19" LCD Monitor
Monitor keeps shutting off with light staying blue as if it was still on.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the monitor, this will solve the problem and will never experience such thing again.
Take care.
Jul 16, 2010 | X2Gen MG19MY 19" LCD Monitor
Srtyws
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
Mar 11, 2010 | Sony SDM M51 15.1" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Power of the Monitor keeps going out.
You need to look inside your pc and check and see if the video card is plugged in tight. Sometimes if it is loose, and it isnt connected, and causes the monitor to not show any picture, but still has power.
Jan 16, 2009 | Sony SDM-HS95 19" LCD Monitor
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
