Question about Dishwashers
Need wiring diagram for a hotpoint df22 dishwasher on/off switch, the switch in it has been replaced with the wrong one so i have no reference to connect up the new one. thanks
    Problem Solver:
  • 5 Answers
You're in luck - I've just had one apart to repair the wiring loom.
The door switch is a simple two-pole latching switch with the wiring as follows.
This is the order of connections from the front.
1. Brown - Live (fed from mains)
2. Red - Load (goes to controller)
3. Black - Load Neutral (return from controller)
4. Blue - Neutral (goes back to mains)
By the way - the flat wiring loom gets fatigued at the bend at the bottom of the door and will eventually short out. Easy to fix with heatproof cable stripped out from an immersion lead.
Posted on Sep 23, 2008
My hotpoint dishwasher super plus df22 stopped working and when I looked at the back of the machine it was black and bubbly. Is this normal?? It looks as if it has overheated. The plug had actua
best to consider it not safe to use until it has been tested by a qualified electrician
he could also explain what happened and the fix for the fault
Nov 02, 2016 | Hotpoint Refrigerators
Why is control panel blank?
This is the only wiring diagram hotpoint has on this machine.
Hope it helps
Feb 09, 2016 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Wiring diagram
see the basic diagram and use the VOM for fix it. God bless you74877101-f7a1-4373-a5b7-410a4340ccc6.gif
Jun 13, 2013 | Hotpoint-Ariston LFT 228A 23 in Builtin...
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
My Hotpoint FDW20 dishwasher does not heat up and is washing cold. Could you, please, suggest a solution to the problem. Can you also forward me a circuit diagram for the machine along with a manual with...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 17, 2010 | Hotpoint Dishwashers
Hotpoint DWF33 doesn't start
yes... check the wiring to the unit... get underneath your unit and make sure that a wire is not "grounding out" by making contact with a metal part down there on a section of unjacketed wire... this would definately trip your breaker and can blow wires apart with a pop.
there may be enough contact to get the initial display you describe... make sure all the wires are insulated properly and wire nutted together securely before resetting your breaker and checking the unit again.
Sep 02, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Bosch Dishwasher SMU 2046
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Oct 20, 2008 | Dishwashers
Door lock assembly Hotpoint dishwasher
Hello.
First switch off the power.
Get the cabinet door off, start by removing the side screws that hold the door (please have someone to help you, holding the door, because this doors are heavy.)
After you removed the door, remove the screws holding the fascia (about 2 on each side + 2 holding the door lock).
Remove the fascia and you wil get acess to the door lock, disconnect the wiring from the micro switch, connect the new par and reverse the process.
Cheers
Aug 27, 2008 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
