Question about Dryers
Motor on fan feels hot
I took apart two fans today to clean them. I noticed no problem withe Pelonis fan (both on stands), but the housing for the motor on the WindChaser fan was pretty warm to the touch. In this weather, both of them run nearly 24/7. My question is this: is it dangerous to use it when I'm not home? Will it overheat and catch on fire?
Thank you.
  • 254 Answers
If I were you I would turn off the fans when you are not at home. These are run by electric motors and by thier design as houshold and not industrial they do need time to cool. These are not designed to be ran 24/7.
Hope this helps Ya
Posted on Jul 05, 2008
Sounds like fan inside blower housing is hitting something when motor is running.
It sounds like you may have a cracked or broken impeller
Nov 10, 2014 | Vacuums
please check in bios the CPU temperature if its 36 degree its fine else remove cabin and clean the fan with brush or use blower to clean
Feb 16, 2014 | HP ProBook 4430s Notebook
Hunter ceiling fan motor is hot
I put my ceeling fan up today but I have just noticed the motor is reslly hot ,,,, HELPPPPP
Jul 01, 2012 | Hunter (25417) Ceiling Fan
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
The fan won't turn on at all.
Turn the fan to the on position and feel the motor casing. Is there any vibration at all? If not, refer to your operating manual to see if there's a fuse that can be replaced. Spare fuses are sometimes attached to the cord. Also try slightly spreading the 2 prongs that conduct electricity through the wall socket for good contact.
If you DO feel vibrating, try a maintenence cleaning and lubrication with either Graphite powder, 3 in 1 machine oil or WD40. I will take you through the steps:
1) unplug the fan
2) there will either be flip releases or notches to slightly pry loose the protective fan SCREEN blade housing. Pop this off and clean + dry it, set aside.
3) With fan blaeds exposed, look at the very center of the blades. There will be a large plastic nut that turns counter closkwise to release the fan blades. Do this, clean blades with warm soapy water. Rinse, dry and set aside.
Behind this will be another large plastic nut that releases the back side of the blade housing. This nut should turn closkwise this time. Again, clean, dry and set aside.
4) You should be down to the motor, stand and fan motor stem. Check for residue build up and clean with a Qtip. You can still remove the housing face and clean behind this if necessary. There will be several screws holding this on. Wiggle apart.
5) Lay fan on its back with the fan motor stem facing up toward the ceiling.
6) At the base of the stem, one small tap of one lubricant of your choise. No more than one quick shot WD40 or 2 drops 3 in 1 machine oil.
7) By hand, gently turn the motor stem closkwise to disburse lubricant. Wipe off any excess with a tissue.
Follow the reverse steps to reassemble. If you had latches on the face, line up the notches or the name on the face to be level at allignment. If you had to pry the face off with a flat blade screw driver, again line up the screen guard (face) and pop/squeaze it back together.
This maintence should be done twice per year to assure a long life! They are made to come apart for maintence so don't be afraid. Take pictures as you go for easy referrance. It relieves you of the tension of remembering what went where! Hope this was helpful!
Sep 22, 2011 | Windchaser 16 Oscillating Stand Fan, With...
Old emerson electric window fan, does it need oil or to be oiled, my dad has had for many years, I've been noticing a burning smell when fan runs for a long period of time
  • First think I think when I hear of a burning smell is have you cleaned out the motor housing real well lately. Lots of fuzz, dust, etc can build up in there and make that motor really work hard and start to make it want to overheat or over heat. Unplug the fan and take a tooth pic and get in the motor assembly and pull the lint etc out of there with it. Some canned air may help a bit to once things are loosened up.
  • As for lubricating the fan you won't oil it. The motor spins the fan so there is nothing to lubricate. When the motor goes the the fan stops so the best thing you can do is strip that fan the best you can and wash and dry the parts real good and clean the motor housing out real well to let that motor breath as much as possible.
  • When a fan motor gets old and is worked real hard it can get hot by default and things will smell hot. If the fan has already been cleaned real well the best thing you can do is give it a break more frequently or look into a replacement motor.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 14, 2011 | Emerson Dryers
How do I open the shell tower to clean the inside? SMC (Shell Electric Co. Model # TWS5
Here is some useful information for your product (as I had the same question today). The first link is to the official product page. The second link is to the PDF Form of that product's Manual. The third page is to a WikiAnswers tutorial of how to take it apart and clean it.
Sep 07, 2010 | Heating & Cooling
Everstar MPK-10cr blowing hot air
Sound like the back lower motor that turns the fan wheel in the back has failed or needs to be lubricated. I used a little bit of silicon spray since it resists moisture. You can try taking the back off...then the front...then take loosen the front motor fan wheel housing and lift up enough to access the lower back fan motor. I then sprayed the motor housing openings as close to the inner part as possible. That also stops the common noisey fan issue.
Jul 20, 2009 | Heating & Cooling
Dryers Logo
299 people viewed this question
Top Dryers Experts
