Question about Kenmore 24032\24036 Top Load Washer
My washing machine water wont drain,it is a kenmore 90 series.
  • carl arellano Feb 16, 2009
    kemore washing macvhine wont drain.could it be the pump it self ? the switch makes a sound when activeded. but wont drain.
  • 481 Answers
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Posted on Jul 07, 2008
How can I fix the lid? I removed the piece of rubber on the lid, now it's working but i would like to fix it.
Posted on Sep 14, 2008
Wont drain kenmore washing machine, top loading
Posted on Feb 16, 2009
Why is my kenmore 90 series model 20912 flooding wall drain pipe when it drains
If the water ios coming out of wall drain time to call a plumber your drain is blocked, laundry drain is usually lint from washing machine.
Feb 10, 2018 | Kenmore Washing Machines
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Kenmore 90 series washer model 20922 wont drain
have you tryed blowing back the drain pipe to clear and sourse of fault,also is the water element heater working ok?it could be waiting at a thermostop position till its up to correct temp,hope this helps
May 27, 2009 | Kenmore 15944 Top Load Washer
Kenmore series 90 wont fill up to large load level
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
372 people viewed this question
Sal De
fordexpert
Robert Rankin
