Question about Casa Vieja Probe White Ceiling Fan
Casa Vieja Intrepid Remote Control Sensing Problem
I had to replace both the remote and sensor for my Casa Vieja "Intrepid".  Long story short, when the light housing is not attached, the remote will work from any distance in the room.  Once the light fixture is re-attached, the only way for the remote to activate or stop anything is by literally bringing the remote within inches of the remote sensor housing about the light.  The replacement remote is a "04756 remote Old Non LCD" and the receiver is the, "28848 Receiver 70639A Current Grey".  Any ideas?
  • mawebber Jul 06, 2008
    The sensor and remote were purchased at the same time, and I was told they were the right parts.  Are you saying that one is incompatible with the other?  If so which is the bad item?  All I know, is when the light fixture is not affixed to the ceiling lamp the remote works without issue.  As soon as the light section is attached, suddenly the remote has to be approximately 2 - 4 inches from the sensor housing.  Thanks
    New Friend:
I have a problem and would hope someone here could shed some light. We bought an home has two Casa Vieja ceiling fans, 4 lights underneath the fan blades and one pull chain. I tried to take the conical top off to see if there was a sensor under it as suggested by a lighting shop so that the remotes left behind could also be programmed to the same frequency. The remote has 5 pins that you can flip up or down in any combination you want. We were told the fan had to be the same. But upon removing the conical sphere at the top it only houses the wires and would have fallen to the floor is I had removed more then 2 screws.
My question is this: if this fan set up to receive a remote frequency to turn it on or not?
Thanks, Mike
Posted on May 15, 2013
I had the same up close problem with mine. I noticed the 9V battery clip connection to the battery was slightly loose. After tightening female side of the battery clip in the remote with pliers I can now operate the fan from anywhere in the room. My guess is the voltage drop across the bad connection kept the remote from transmitting as far.
Posted on Jun 09, 2009
  • 417 Answers
You need the same sensors in the remote as the one ur using now the old sensors will not work
Posted on Jul 05, 2008
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
Why does the light go on by itself
Change e frequency settings in your remote and you should be OK.
Jul 12, 2014 | Casa Vieja Probe White Ceiling Fan
The globe for my casa vieja ceiling fan broke. where can i buy a new one? how do I measure the size to know what I need?
You can find replacement globes at most lighting or building supply stores. The dimention you need is the diameter of the circle that the globe sits into.
Apr 30, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Newly replaced circular light bulbs flicker and strobe in Casa Vieja Ceiling fan and eventually burn out. Do I need to change ballast resistor?if so How do I change that?
Take the light down - a two person job in case you dont know it. Find and remove the ballast. Take it to a electric supply store and get a replacement. Get a new lamp at the same time.
Feb 20, 2010 | Casa Vieja Probe White Ceiling Fan
Remote Control
I had the same issue. I had to replace the remote control reciever located on the fan and that did the trick.
May 05, 2008 | Casa Vieja Probe White Ceiling Fan
Casa Vieja Probe II Ceiling Fan
look on the side of the canopy there should be a slide switch. if moving this switch has no effect, then either the switch is faulty or the connections to it may have fallen off.
Aug 22, 2007 | Casa Vieja Probe White Ceiling Fan
Casa Vieja Probe White Ceiling Fan Logo
985 people viewed this question
Top Casa Vieja Dryers Experts
Stan Ford
Tom Chichester
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
