Question about Steam Fast SF-450 Iron
Parts I have a steam fast sf-450 and the fitting that the steam hose attaches to has snapped off. I believe I can easily replace the fitting, if I can find one, as it appears to only have two screws attaching it. Am I correct and, if so, where can I get this part.
  • Anonymous Aug 15, 2008
    I had the same problem last night. Can't find parts or service for this item.
  • robertgross Apr 23, 2009
    My hose connection has also broken off. I have disassembled the unit and am looking for spare parts. The part is a simple hose connector but is custom molded for this unit. A hardware store replacement hose connection will not make a pretty replacement and the hose may need to be cut to make it work. A automotive clamp may be used on the unit but quick disconnection of the hose will not be possible with this solution. If you are handy and have time you can make it work. If not, perhaps purchasing a new unit is a better solution.
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Posted on Aug 19, 2008
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
The cap is stuck unable to open to fill?
I had the same problem. I sprayed up into the bottom of the cap with liquid wrench, let it work for a while, then had to use large pliars to twist the cap off.
Jan 27, 2010 | Steam Fast SF-220 Iron
Steam Press sp-660 will not steam with distilled water
Steamfast brand SP-660 steam press
contact Top Innovations
1-800-711-6617
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Steam Fast SF 680 arm is hanging up
Top Innovations, Inc.
6655 Troost Ave.,
Kansas City, MO 64131
Dec 27, 2007 | Steam Fast SF-680 Iron with Auto Shut-off
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
Steam Fast SF-450 Iron Logo
441 people viewed this question
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
