Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1231 w front load washing machine
I have just purchased a new mother board for my machine as the old one blew up. i need a diagram of the wiring to re install it. any chance that i could get one from somewhere as the machine is only 2 years old and its a fantastic machine and i need it..... not too prepared to buy new one after this time. i had my old one for over 20 years and had no problems with that one but it got too old and i needed a change. so please if you could help it would be great. thanks. Maura
    President:
  • 1,462 Answers
All connections to the zanussi modules are plug and socket and are keyed so you can't put them in the wrong place
Posted on Jul 05, 2008
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Sep 12, 2008 | Zanussi ZWF1430W Front Load Washer
PROBLEM
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF 1421W power failure
most likely caquse is door interlock. only way for you to test is to substitute
May 08, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
292 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
