Neptune front load washer stopped due to out of balance load. Now wont start turning, has a humming sound
  • Debie Beyer-Pacheco Dec 15, 2008
    Machine stops with a LR error at the spin cycle and will not spin. Husband had to wring cloths out by hand and then took forever to dry - now I cannot even get it to begin the wash cycle.
Went through the test program in the installation/service manual, which was taped to the back of the washer. It indicated that the drain .pump was not operating. Checked voltage to pump- OK at 116V. Pump was stalled and getting warm. Dismantled motor from pump housing and found impeller was stalled by a broken toothpick. Reassembled and washer now operating normally.
Posted on Jul 07, 2008
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Washer walks when it spins
It is probably due to the unbalanced load in the machine and
when spinning,it will make this motion.Try to balance the load
better when washing.
Apr 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load washer not spinning correctly
IT SOUNDS LIKE THE PAKING STRAPS MIGHT NOT HAVE BEEN FULLY REMOVED, OR THE HAS BEEN A SMALL CLOTHING ITEM THAT SLIPPED THRU THE OPENING WHEN YOU OPEN THE DOOR THERE IS A SEAL AND IT IS VARY FLEXABLE SOMETHING COULD HAVE GOT THRU, BUT IT STILL SOUNDS LIKE THE PACKING STRAP WAS NOT REMOVED ALL THE WAY IT COULD HAVE BROKE OFF WHEN BEING PULLED OUT, IT'S JUST A PLASTIC STRAP BUT MIGHT HAVE TO REMOVE THE FRONT COVER TO GET TO IT,
May 29, 2009 | Maytag Neptune MAH9700 Front Load Washer
Draining neptune washer
The sloshing sounds you hear are supposed to be there. Actually, it was there when you first purchased the washer and had never used it before. It's part of the balance system. When the machine goes into high speed spin, the balance system kicks in. The water portion of it is forced outward by centrifugal force. Now when the machine slows down and stops, the water settles back down so that when you reach in and turn the drum by hand, you can hear it sloshing about.
Hope this helps,
SG
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mah2400aww
The problem is the washer is defective.
Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
