Question about Sony Ericsson Cell Phones
Cleaning of K850i cybershot phone
I need to know how to take apart so as to get to the camera lens for cleaning purposes... gets dusty because of work.
    Brigadier General:
  • 7,752 Answers
It is always best to have a professional tech do that for you to pervent any damage being done to the phone.
Posted on Jul 05, 2008
I've got some visible(I see it on the pictures and on the digital display) dust (tiny hairs etc) on my lens (actually inside) so it seems I can't get rid of it without taking my cam apart. The dust is then...
If this is a fixed lens camera (you didn't give a model) I'd suggest strongly for you not to attempt to take it apart. Hopefully what you are experiencing is dirt on the outside of the lens. If so turn on the camera huff (breath) on the lens to create a slight amount of moisture and then use a lens cleaning tissue to gently clean the lens.
If as you say this dirt is on the inside then I would suggest getting it cleaned by a camera repair facility. Problem there is a lot of these point and shoot cameras cost more to clean and fix then it does to just go get another one.
Next thing if the inside is dirty they you must have a lot of lint in your pockets or you have been using this camera in a dusty environment. For carrying it would be best in an actual camera case rather then an open pocket and for dusty condition I've used shallow water camera bags and I've also used ZipLock bags while photographing a waterfall.
Apr 12, 2011 | Panasonic Cameras
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
The cover lens of my k850i wont close
the camera trigger is damaged on the back of the main board needs to be replaced for software and hardware repairs contact kas at kas-anjum@hotmail.co.uk
Feb 17, 2009 | Sony Ericsson K850i Mobile Phone
Sony Cybershot DSC-P41 Bouncing Screen
First try sqeezing the camera very hard, if that doesn't work slam it as hard as you can in your hand. This usually solves the problem.
Feb 15, 2009 | Sony Cyber-Shot DSC-P41 Digital Camera
Pics show up black
Camera is already fried / damaged so take it apart and do some research on lens specially on shutter built in lens mechanism.
Jan 10, 2009 | Sony Cybershot DSC-T200 Digital Camera
Cleaning and maintenance for minolta x370s
a fine camera for a student learning photography.
pull up the rewind knob to open the film door, using a soft brush clean the film chamber and takeup spool area don't touch the shutter. a q- tip for the finder. take off the lens and clean with soft tissue the front and back lens. unless the mirror is really dusty don't touch it. remove the battery and clean the contacts if needed. you can clean the camera body with a soft cloth.
Dec 11, 2008 | Minolta Photography
Sony cybershot 6.0 mega pixels
Hi
Do you mean the outer lens covers that open and close when you turn the camera on and off, or do you mean the aperture inside the lens that adjusts the amount of light that gets through?
The outer lens covers can usually be repaired if you can get the parts, or you can try taking it apart, cleaning it and then put it back together.
If it's the aperture then you can maybe repair the lens by tearing it down and rebuilding it, or you can replace it yourself or have somebody replace it for you.
We are a digital camera repair shop, we have W55 lens repair listed in our store for only $65 if you're interested just let us know.
Good luck from Darntoothysam com
Thomas
Oct 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Powershot SD30 taking blurry pics.
dust could have gotten insode making the focus lens to stick.
you might have to take it to a camera shop for a good cleaning.
dusty places are always bad for electronics.
but sounds like the focus lens is failing, there might be an option to clean the lens electroniclly, most canon has the option. not sure about sony.
good luck
Jul 14, 2008 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Cell Phones Logo
89 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
