Question about MSI KM4M-L Motherboard
It continues to freeze!!!!
I've removed one memory slot, but it still freezes
    Scholar:
  • 55 Answers
If you are worried that it is a memory issue, try downloading the free and excellent Memtest 86 from here:
http://www.memtest86.com/
You can make a bootable CD which will soak-test your memory - if it will run overnight without an error then it's almost certainly not a memory issue.
Otherwise, have you tried a complete BIOS reset? This can get corrupted in ways that simply reverting to factory default won't fix. There is usuall a link on the motherboard which will clear the BIOS settings (you may need to remove the BIOS battery first). You can then start a-fresh.
Posted on Sep 22, 2008
Gateway fx 6800-01e mouse freezes
This is an indicator that the rams is damaged. Its not the mouse that freezing its the entire system keyboard etc,
the solution is to replace the rams. Open the side panel, remove the memory module (rams), Its located in a slot held together by 2 clips its a circuit board, thin and long in a slot cant miss it. But the exact same one and replace it.
Dec 26, 2012 | Gateway FX6800-01e PC Desktop
My computer is continually freezing everytime i restart it. how can i fix it. sometimes it will simply refuse to go through the startup and freeze after the original asus symbol is shown.
Freezing can be bad memory among other problems. Try removing a stick and see if you can boot. If not, swap sticks and try again.
Memory is not that expensive so buy more and try above.
Mar 13, 2010 | Computers & Internet
Dimension 3000 keeps freezing
Sounds to me like the hard drive might be going bad. Bad sectors on the hard drive can cause the freezing to happen.
If you have a spare known working hard drive, put that one into the system and then install windows xp on it and see what happens.
If that doesn't do it then try each memory stick one at a time in each slot one at a time and see if the freezing goes away. If it does then you know its a memory stick problem.
Also unseat and reseat the CPU into the slot and make sure there is not dust or dirt in the socket that the CPU sits in.
After all of this if you still have freeze up problems then the motherboard is bad.
Nov 28, 2009 | Dell Computers & Internet
My htc 6800 contnues to freeze up
i would suggest a master reset, hold both soft keys and then hold reset button on bottom by memory card,
Jun 25, 2009 | HTC PCMICROSTORE Brand Mogul XV6800...
Laptop sony vaio freezes without the memory stick inserted
Try to copy the whole content of your memory stick to directory C:Windows/System32 and restart it. Or try to put your booting priotity (Used to be by pressing 'Esc' key several timesduring start up). GoodLuck!
May 09, 2009 | Computers & Internet
Fallout 3 freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Freeze problem, please help me
Turn of all power then unplug battery, disc drive, and make sure there is NO POWER on at all. Now take the laptop and turn it over and remove both or if you only have one memory Modules, If you only have one try it in the other memory slot and try to reboot laptop. I you have two module remove both and only replace one and see if it boot up normal after that, I think that may fix your problems, I have seen sometimes the memory module gets loose and will cause a freeze up. Hope that solves your problem
Dec 10, 2007 | Dell Latitude D800 Notebook
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Sep 09, 2007 | Nokia N95 Cellular Phone
MSI KM4M-L Motherboard Logo
292 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
