Question about Karcher 2500 PSI Pressure Washer
Hooking up detergent to pressure washer
How do you hook up detergent to the pressure washer?
    Champion:
  • 313 Answers
Detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
2 Suggested Answers
  • 199 Answers
SOURCE: Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
Posted on Jul 20, 2009
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I have a troy built pressure washer and have problems locationing the hook up for soap dispencer
just before the pressure hose should be a t fitting with a hose barb.
Sep 16, 2014 | Garden
Does it hurt a pressure washer to run hot water thought it went they hook up the water for outside to hook it to the hot water i did not no it and i hook it to the pressure washer
most pressure washers have packings that can sustain a temperature of 140 degrees although it as strongly not recommended since the pump head heats up when in bypass mode(triggergun closed)best rule for pressure washer is never leave the trigger closed for more than 3 minutes even with a thermal sensor:):)
Jul 31, 2013 | Karcher 2500 PSI Pressure Washer
Where are the filters located on the craftsman 2700 power washer
The only filters on a pressure washer are: Where the hose hooks up to the pump there is sometimes a washer with a screen inside it. The syphon hose usually has a fine filter on the end that drops into the detergent. If this question is related to your other post see my answer there.
Aug 30, 2012 | Craftsman 2500 PSI Briggs & Stratton...
Detergent tank will not draw.
Detergent tanks will only draw at low pressure. Switching to low-pressure is done is several different ways with different makes/models. Some pressure nozzles are push/pull, some are twist and some just have a quick coupling and you have to keep up with a low pressure tip (usually colored black).
If it will not draw at low presser, it is either stopped up with debres, or the check ball inside the injector is stuck. The injector is the little device that is just before the outlet where the pressure hose hooks up. These always have a small metal ball, held in place with a tiny spring. This ball is there to prevent pressurized water from shooting back into the detergent tank. The ball and seat that it presses against can get stuck together with old detergent residues, calcified deposits from the water or even rust.
Use a small crescent wrench to take it apart -- or if you prefer, find the right size box end/open end (metric) wrench. Be very cautious as it comes apart because that little spring can leap out and they are hard to find.
I hope this is helpful to you. If it is, please take a sec to rate me. Thanks!
Don
Mar 10, 2012 | Karcher K 391m Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
How do I hook up and use soap on model 020228 pressure washer
There are different nozzles. One for detergent, Max, General and Delicate. The detergent one is more a less a soaker its opening is the biggest (less producing pressure), it's the one that must be used to siphon the soap out of the container none of the other tips will allow to siphon. I hope this is helpful to you please rate this answer on how helpful it was. Good Luck and have a great weekend.
Apr 01, 2010 | Briggs Stratton 020273 Elite Series...
Jul 20, 2009 | Garden
Water keeps popping off t he detergent cap.. even though water is not even hook up.. guess it is detergent popping out .. what is wrong with it.. cleaning fitting is not even on
detergent non return valve stuck, allowing water to back feed into the chemical tank.
depends on what machine it is as to where the non return valve is.
Jul 17, 2009 | Karcher Garden
Karcher 2500 PSI Pressure Washer Logo
775 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
