Question about Thermador C302U Electric Double Oven
Trying to get my self cleaning oven to start....I am not the original owner of this property and I do not have the owner's manual. My oven is about 10 years old...double oven, microwave, convection. Also, can't figure out how to set the clock.
  • Julie Ortiz Jul 05, 2008
    98090109....cmt227nprs...
    Master:
  • 848 Answers
Try this one the oven has a feature where you set the time for it to begin cleaning and the time for it to end cleaning.
Next to the clock in the middle of the back are two dials. The top one is the start time, the bottom one is the end time.
I suggest 2 hours to allow a good cleaning.
The locked light will turn off when the cleaning is done, allowing you to open the locking lever.
Posted on Jul 05, 2008
  • 426 Answers
Does the clock have a dial handle or, a digital clock?. to get the oven in clean mode you need to make sure that the door is locked, turn to auto/self clean and wait about 5 mins (see if the stove comes on) if it doesnt come on then set the timer for around 5Hours...
if you could e-mail me pictures of your stove i will be able to assist you further, (with more detail) Feel free to e-mail me at fixya at whypayforhelp dot org
i will see if i can find a manual for you
~Lee
    Genius:
  • 1,847 Answers
May i have the model and make of the oven?
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Self cleaning option beeps only after a few min. and stops heatin
It was simple. I called GE's toll free help number and they told me what to try and it fixed it immediately!
Mar 25, 2009 | GE Ovens
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
I am not sure if I am setting the clean mode correctly.
Most self cleaning ovens that I have been around clean in 1-1/2 to 2 hours. See you Owner Manual to be sure.
If you can't find your Owner Manual, let me know, I'll see what I can dig up.
Jan 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador C302U Electric Double Oven Logo
218 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
