Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Shuffle prob my ipod shuffle get washed in water i placed it in the sunlight it works bt nw the prob is it is nt charging any solutions
  • 8,596 Answers
Water = dead player; sorry
Posted on Jul 06, 2008
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
I have a i-pod shuffle 2GB, bt i dont know how to start it or what is required to do to get it started??????? plz help
Is it a new item to you? If, so, it may need to be charged prior to your first using.
Refer to this page for How To's on the ipod shuffle. Click Here
Mar 14, 2011 | Apple iPod shuffle MP3 Player
Msg Opening Prob. N70
As you said You deleted SOME SYSTEM FILES
  • Try to avoid editing in System files if YOU R NOT SURE ABOUT THE FILE
Anyway you might be deleted sys file supporting to open Msg....
Now Do following....
  • Press CALL button
  • Press *(Star)
  • Press 3
  • Press Power ON
HOLD IT until it appears/ Blinks Nokia TWICE....Or for few minutes....
YOU ARE DONE.......ENJOYYYYYYYYYYYYYY........!!!!!
AM HERE too
Mar 28, 2010 | Nokia N70 Cellular Phone
I washed my daughter's ipod shuffle which was in her jeans pocket
These are never easy situations to experience, but I can only advise you to disconnect the iPod Shuffle for the computer, make sure it is turned to "Off" mode and allow it to sit in a place where there is sunlight or heat for at least 3-4 days untouched.
I have heard this process being done by a few folks for different iPod/iPhone devices, so hopefully this will work for you.
This is however, the only suggestion in such cases where an electronic device like your iPod shuffle has been subjected to moisture or water.
If this still does not help, you will more than likely have to take the iPod Shuffle in for service at an Apple-authorized iPod repair center or unfortunately replace it with a new iPod.
I hope this helps and you are able to get your iPod back to functionality again.
Regards,
-Terry
Mar 12, 2010 | Apple iPod shuffle Second Gen. Silver (1...
I left my ipod shuffle in my washing machine.Now I cant get it to work,or to charge it!
If it actually went through a wash cycle I don't think that theres much hope of it working again.
Mar 25, 2009 | Apple iPod shuffle MP3 Player
Ipod got wet wont hold a charge and wont switch to play list i accidentally left my ipod shuffle in my pocket and then it got wet in the washing machine it was in there for about 30 seconds please help
You probably already have the answer to this, but if you send it to Apple, they may just give you a new iPod. If they even think that it got wet, though, they won't fix it. You will have to replace the battery. There are a number of places that will do that for you. I hopw that helps.
Oct 19, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Shuffle
Water = dead player; must be replaced
Jul 05, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My Ipod shuffle does not work, when I switch on the ipod, I see orange light on and off..it does not show green. I charged the battery for more than 4 hours. Can anyone help ne why is this happening and...
I am not sure about the 1st generation but the 2nd generation definitely charges via the USB connection. If you don't hear the music its because there are no songs on your device. When you initially add songs, they go to the Library in iTunes, not the Shuffle. Just drag and drop your songs from the "Library" to your "Device" in iTunes and then you'll notice them get sync'd with the Shuffle.
Jan 14, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Cant get shuffle to work when not conected to pc
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Sep 15, 2007 | Apple iPod shuffle MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
82 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
