Question about Gateway MT3705 Notebook
Key board i 5 keys on my gateway that will nt work. left shift- v
    Problem Solver:
  • 15 Answers
Best solution for this is to get another keyboard, try e-bay to see if you can find one cheap
Posted on Jul 05, 2008
Accessing the functions above numbers keys?
hold down shift key it will be near left bottom corner of key board. While you press 7 key. there may be another shift key on the bottom right hand corner of key board.
Jun 08, 2016 | Office Equipment & Supplies
Gateway M460 capitalization issues
Try both shift keys, the left one may have died. Otherwise use Caps Lock.
Try this:
Navigate to Control Panel and double click Keyboard.
Select the Driver Tab at the top.
Now click Update Driver.
Updating the driver may work, otherwise a new board may be needed.
Take care!
damnor01
Sep 21, 2012 | Computers & Internet
I got my wife a mouse and key board a little wile ago' and she just now tryed to use it. the key board works but the mouse dase'nt how do i get it to work
If its a wire less type check if there are batteries inserted and if the red LED lights up. If they do just click the left button to make it active. Even if you do not use it for more than 5 minutes the mouse goes into power saving mode, just left click to wake it up.
Aug 16, 2011 | Computers & Internet
I have a Gateway Netbook and many of keys have 3
Bruce, you need to use alt depens on the side if it shown the right side press alt on right if its on left pres alt from left
Apr 28, 2010 | Gateway 2520915 Keyboard
Keyboard key not working
have you use the cobination of shift key when using this dash and equal key
dash+SHIFT PRESS BOTHE THE KEY TOGETHER.
Sep 16, 2009 | Gateway 2520796 Keyboard
I cant get my 'at' key to work.
Try using the other shift key. If that works, then you most likely have a dirty or defective keyboard.
Does the number 2 work? Does your shift key product uppercase letters (does it work with other keys?)
If you are having problems with a flaky keyboard, it's pretty inexpensive to replace it and reduce your stress.
Jan 20, 2009 | Gateway 2520915 Keyboard
It didn't work!
Yeah, it happens this way many times. The shift keys on the board are linked, both right and left have the same function, and therefore use the same circuit in order to work. When one goes they both go, and, unfortunately, replacement is the only option. Sorry.
Aug 25, 2008 | Gateway 7330GZ Notebook
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
Gateway keyboard shift key creating special characters when used
This is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://www.sportmachines.com/keyboard/
Jan 30, 2008 | Gateway 2520915 Keyboard
Gateway MT3705 Notebook Logo
199 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
