I have purchesed this week an Azur 340R AV Receiver from Richer Sounts at Nottingham. I intended to use it with my SKY HD Sstelite box, also with my Freesat HD box. I used SKY satelite on video 1 and got picture and sound. I used Freesat on video 2 and only got sound. When I swopped them aouund I got sound and picture from Freesat and only sound from SKY HD box. In the manual it states that inputs have to be asignable to the different inputs. But to be available to do this I need to get OSD menu on screen and I have to have Composite RCA connections 75 ohm - video phono. I do not have this on my SKY HD box or my Freesat box or TV. I asked the Sales Assistant at Richer Sounds for advice. He read the manual and was of the opinion that the AV receiver should be 'plug and play' Can you please give me advice Many thanks Alan Garrod email - margaretgarrod@sky.com
5 Suggested Answers
  • 17 Answers
SOURCE: No OSD on TV connected thru composite video (Monitor Out)
for the tx-sr606, the onscreen display will only show up when you connect the receiver using HDMI out to your tv. this is indicated on page 22 of the user manual.. hope this helps.. ^_^
Posted on Nov 28, 2008
mlapres
  • 757 Answers
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Posted on May 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: I am using an optical
In any 'connection' question there are at least two participants and specific answers require specific details about all components in the path.
Does the center speaker work for just speaker testing? Your unidentified BluRa player has to know there's a Center Speaker, too.
Digital bitstreams don't arbitrarily drop out one channel.
Posted on Sep 24, 2011
clifnut
SOURCE: Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Posted on Sep 06, 2012
I am using an optical cable to from my Panasonic Blu-Ray player to my Cambridge Audio Azur 340R receivable, and the centre speaker is not working
Sep 24, 2011 | Cambridge Audio Azur 340R
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Wife moaning at sound delay.......why.....
The sound delay would not be caused by hooking amp up but must be a software problem in sky box. Try to get an off air station with a antenna and see if the problem persists.The dvd recorder should see your sky box output first then out from recoder to tv.Then use tv audio out to amp,or tv audio out to amp. RANDY
Mar 16, 2007 | Cambridge Audio Azur 540A Amplifier
67 people viewed this question
 Grubhead
Grubhead
