GPS Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to find a position from GPS coordinates? - Garmin GPS
Anonymous
Level 3:
  • Master 321 Answers
  • Posted on Dec 25, 2010
Anonymous
Master
Level 3:
Answers
321
Questions
0
Helped
110580
Points
1111
If you know the proper geographic coordinates of your destination, You can easily navigate around your destination using the longitude and latitude coordinates or other coordinate formats.
  1. Touch WHERE TO on the screen,
  2. Touch COORDINATES from the list,
  3. Touch FORMAT to change type of coordinates. Because different maps and charts use different position formats, the nuvi allows you to select the correct coordinate format for the type of map you are using,
  4. Enter the coordinates and touch DONE.
That is how you find a position using the coordinates, but you have to be very familiar with coordinates to be able to use it.
Complements of the season to you over there.
5 Related Answers
TO Lady
  • 638 Answers
  • Posted on Apr 01, 2008
SOURCE: Converting GPS coordinated to google earth coordinates
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Anonymous
  • 504 Answers
  • Posted on Feb 10, 2008
SOURCE: gps coordinates
If you are asking to put latitude and longitude information into the C330, no, the unit is not designed to accept that type of information.
Anonymous
  • 53 Answers
  • Posted on Aug 31, 2008
SOURCE: Garmin always 1/2 mile left of actual position
it could be the unit or the film on the windows of your car .... most of the time it is the unit messing up i have ran into this problem a few times installing
Anonymous
  • Posted on May 01, 2009
SOURCE: GPS Coordinate Conversion
Just take the last 2 pairs of numbers and divide them by 6.
Example if it is 37 38 it would then be 623.
Anonymous
  • 1111 Answers
  • Posted on May 10, 2010
SOURCE: How do you enter coordinant into GPS to find a
the 1212 will not do what you want it to do...its just not capable of taking longitude and latitude.you can get copy of your manual for your 1212 here
.probably the easiest way around this problem, is to get the address somehow (was there a phone number provided with the rv location list)
if you know the approximate location, you can use google maps to zoom in and get a street address
google maps here
you could also use google earth if you have it..if not, you can get it here very cool even if youll only use it once.
you can enter longitude and latitude in google earth
let me know if you need more help
good luck
How do I program my lowrance to locate reefs if I have the lat log reference?
You can go to your GPS page and zoom out and then using your cursor pad and move your cursor so it is in the general area of your coordinates. Start zooming in andifferent as you do the the lat, long readings on your screen will become more precise. Continue to adjust your cursor position so the coordinates match up with known position you have. Continue until the cursor position on screen and your known coordinates match.
Push "ENTER" twice. Your way point will be saved at the current position of the cursor.
OR
Push your cursor pad to bring up your crosshairs on the GPS screen. Save that waypoint, then go in and edit the coordinates to match your location data and save it. The waypoint you created will move to the new coordinates.
1helpful
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
How do i insert a coordinate to find a spesific fishing spot
The Garmin nuvi's were designed as automotive navigators and not really designed to be used as marine or outdoor GPS units with the exception of the nuvi 550 which is an all around GPS.
The Garmin handhelds are recommended for marine and off road recreational use but it is possible to navigate if you know the coordinates of your fishing spot.
To enter coordinates: Touch Where to? > Coordinates and touch a box to enter a coordinate.
You can also refer to the manual for more information. nüvi® 215
How do i enter gps coordinates into my garmin etrex hc
Hi Jdriscoll38,
Since you probably have been using this device, you know it will automatically receive and lock in on the coordinates from at least three satellites if you move outside to a large cleared area, and power up. I could list all the steps to manually set all the coordinates, and that would take a couple of pages. Download the entire 56-page manual at this site, and refer to the pages below:
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Go to the top of page 20 to change the Position Coordinates.
Right below those instructions, you'll see the info for changing the Elevation.
In case you don't have this manual, after download this, you should have all the instructions you need for all operations.
Let me know if I can help further. Thanks.
Regards, Bill
3helpful
How do i insert a negative (-) deg co-ordinate into my nuvi 200
Positive Lat Lon coordinates are for the eastern and northern hemispheres respectively. If you have a negative coordinate, they indicate a location in the western or southern hemisphere.
To enter a Latitude coordinate of, for example, -31 degrees, you would enter 31 degrees, but specify S (for South) rather than N (for North)
Negative Lon coordinates would use W (for West) instead of E (for East)
Negative coordinate
By entering a negative longitude as a positive degree West of the prime meridian. For example, -4 degrees is entered as W 4 degrees.
2helpful
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
