Question about Whirlpool GBD307PDS Electric Double Oven
Whirpool rbd275yPDT11 no power after auto clean
We ran through the entire auto clean cycle and now no power-door is unlocked and oven is clean. breaker and power fine--How do I get to the thermal fuse(s) to check them. Is there somewhere to get pictures of where to look (what they look like) or instructions. How ridiculous is this for an oven to shut off after auto clean----first time we've used it
  • Anonymous May 25, 2009
    I tried the auto clean for the first time and both of the elements won't heat up. Oven is still new and was used less that 20 times.
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Posted on Jul 06, 2008
We have a Whirlpool dual-oven (over and under) that has the control panel on the top above the upper over. We had the same problem as described, fuse failed during auto clean. I pulled the top cover to get to the power connection and circuit boards. I found a couple of hot-spots on the control board, but confirmed the thermal fuse was the real problem with my meter.
When the fuse fails, it works like a standard switch. It’s either "on" allowing electricity to pass through it, or "off" in its failed state. The only difference is it triggers when the environment around it exceeds its rated temperature. The one described above “Microtemp KLBALY G4A00 TE 110C “ looks to be designed to fail at 110 degrees Celsius or 230 degrees Fahrenheit.
The following picture is taken from above, on the left side, facing forward:
Link to the manufactures web site
Link to the product specifications PDF
All things considered, as long as the Radio Shack replacements specifications closely match the originals:
- Electrical load: 10 amps @ 250VAC (15 amps @ 120VAC, 5 amps @ 24VDC)
- Fail temperature 110 C / 230 F
You SHOULD be ok. But remember, when fuses fail, they usually do for a reason. Just replacing the bad one and the lights come back on doesn’t constitute a “repair”. If you choose to ignore common sense and burn your house down around you, it’s probably a good thing since the gene pool needs a good flushing.
Posted on Jul 03, 2009
Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    Cleaning cycle finished, oven cool but still locked
    Since the clean cycle was interrupted by turning the breaker off it may need to be restarted. Start the clean cycle like you normally would, then after it starts and runs for a couple of minutes, push cancel and see if it unlocks. If not the lock would need to be manually moved by putting a flat thin angled tool or stiff cardboard carefully between the door and oven cavity on the top of the door, slowly move this to the left, you will feel resistance when you get to the latch in the center. If you hit it right it will unlock.
    May 07, 2010 | Whirlpool RBS275PD Electric Single Oven
    Whirpool oven door not opening and no power to oven after self cleaning but also had problem with latch before cleaning
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 07, 2010 | Ovens
    Oven door will not unlock
    Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
    MIchael Anderson
    Anderson Appliance
    (865)945-3808
    Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Cannot unlock self-cleaning oven
    I ran the cleaning cycle again, and it the door opened without difficulty.
    Sep 13, 2009 | Kenmore Ovens
    Whirlpool self cleaning oven, Super capacity 465, door will not close
    I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
    Jul 03, 2008 | Ovens
    Error Code F13 and door locked
    press clear for five seconds if that doesn't work then power down for 30 seconds then on if that doesn't work replace the eoc
    Mar 19, 2008 | Frigidaire FEB30S6D Electric Single Oven
    Oven door won't open after self cleaning
    it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
    Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Door Keeps Locking and Unlocking after Power Outage
    Located the switch - resetting fixed my stove as well.
    Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
    Whirlpool GBD307PDS Electric Double Oven Logo
    960 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
