That is a very common problem faced.
1)check all connections
2)try re-installing pc suite
3)if still problem persists,restore your factory settings of your phone
try to synchronise ur mobile with pc. for synchronising do this.. 1.connect ur mobile to pc with data cable 2.then switch off ur mobile... 3.Now press switch ON button for some second(don't start ur mobile) 4.After tht ur mobile automatically synchronise with ur pc now start ur mobile nd try to connect.
Hi, - To connect karbonn k406 mobile to your pc to your computer you need only a data cable which you brought with the mobile (Accessories).
- But to connect your karbonn k406 mobile to your pc for browsing (internet) you need a pc suite (software). - If the pc suite for your mobile is not available on internet to download you have to contact the nearest service center to avail the pc suite for free.
- After installing the pc suite in your computer connect the mobile using the data cable which you got with the mobile when purchased (if not you have to buy one). Please rate if this solution was helpful, thanks!
You can update you mobile by connecting to you PC and install PC suite And you are using Samsung S5233S so you can download the PC suit from Online http://www.brothersoft.com/samsung-pc-studio-78015.html Use This link to download your PC suit and install it and then after installing just connect your Mobile to your PC using Data Cable Provided while purchasing the Mobile and then select in you Mobile as PC connection then you can see your mobile device in your PC in PC suite Software where right Download you can see a Update Mobile option So using that your can update your Mobile
and install in your system and change the setting in your mobile settings in PC connection select as (Ask On Connection) then connect you mobile to your PC using a data cable and after connecting you can see the options asked in your mobile then select as PC Connection then you can access you mobile using your PC if this don't work just replace the data cable
Wat are you trying to connect to PC...Mobile or Camera or Music player. With the word data cable i assume it as mobile. If you have bluetooth facility in your mobile, you can connect your mobile with Pc by connecting a small device called Bluetooth dongle with your pc. This dongle will provide bluetooth connectivity to your system and your mobile and system can communicate each other via dongle.
If You have a software in your PC and you want it to move to your mobile follow these steps: Connect your mobile to your PC Via Connectivity Cable (it comes with your mobile set along with the required software and drivers for your mobile you are needed to install these drivers and software on your PC first your mobile also have a complete instructional manual that can guide you while connecting your mobile to your PC ). You can also connect your mobile your to your PC via Bluetooth (For this you need a Bluetooth enabled mobile and a bluetooth device for your PC). After connecting your mobile to your PC you'll able to transfer your files from PC to your Mobile and then you can load that software from your PC.
FOR A COMPLETE DETAILED GUIDE KINDLY POST YOUR MOBILE MAKER NAME AND MODEL NO.i.e. NOKIA N96
Thank you for further information please get back here or gimme a mail @ [email protected]
You should visit www.download.com, here you will find lot of software compatible with your phone including PC Suite or visit there web site www.in.lge.com for your needs, hope it will helpLG KG195 has GPRS 10 & Bluetooth enabled. You can use bluetooth to connect your PC to your mobile phone's gprs modem. First you need to enable the GPRS service on your phone from your mobile service provider. You also need to put a bluetooth dongle in your PC to connect it to the mobile. Every mobile service provider has different settings for using the internet on PC. so call your mobile service helpline and ask them to help in connecting your pc to your mobile for GPRS internet.
