Question about Whirlpool Washing Machines
I'm trying to replace the rubber liner in my whirlpool duet washer. Our puppy bit a small hole in the rim, and it now leaks. My husband ordered the part, but can't figure it out.
  • 5,911 Answers
If you are talking about the gray rubber boot around the door, it is called a "bellow". The following link will provide you with step-by-step instructions:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck, or require further assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2008
Leaking from detergent drawer
Have someone disassemble the internal hose to check for a clog in the line. The paper liner from a bleach container was the problem with my own washing machine. After several other chacks my husband had to remove it to spot the culprit. This was hard to spot and check for because it is thin, not viewable, and unexpected. We first tried fishing for any blockage, and there was no way of knowing. Hope it helps
Nov 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello. It looks like the rim of the tub is
sounds like the rubber boot from door to drum is worn.  can be replaced but suggest a pro do it..
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesnt drain properly and leaks waster at the bottom
If this is a Whirlpool Duet, the following link explains what you have to do to determine the source of a leak:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In most cases on a FRONT LOADER, leaks are caused by the rubber door bellow developing small rips or tears due to age and wear. If the bellow is leaking, it must be replaced. The following link explains the steps necessary to do so:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Double check all your drain hoses to ensure they do not have any rips,holes or punctures and all clamps are tight.
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hole in rubber seal on Whirlpool Duet washer
I'd replace the seal. It isn't expensive and it isn't hard to do. You can avoid a lot 'o scrubbing by running an empty load on whitest whites with bleach occasionally and occasionally cleaning out the strainer inlet to the pump, where things tent to collect and fester.
--Regards, --WoobieDog--
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
