Question about Canon Cameras
Canon gs2 video camera power light only comes on just faintly - camera won't power up
I have my canon a470 digital camera, recently i had a problem with my cam, while taking any picture it showing fully white screen pictures not at all viewing properly as well their is a white lines are...
This sounds like there is a problem with your camera's shutter mechanism and won't be resolved by changing your settings. You'll have to get your unit serviced by an authorized Canon service center. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 01, 2011 | Canon PowerShot A470 Digital Camera
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
The canon xlh1 camcorder, can someone tell me which on camera auto light works auto on this camcorder in low light, i've asked lots of sellers of canon video camera lights and nobody seems to know they...
Hi Gerry,
I don't know but I think the chat session was disconnected. Anyway, there is product from Canon itself and the model of the video light is VL-3 Video Light.
http://pc.pcconnection.com/1/1/10726-canon-usa-video-vl-3-video-light-3175a002.html
"Optional light sources provide extra illumination when shooting either video or still images. The VL-3 Video Light connects to the Advanced Accessory Shoe and is powered directly by the camcorder. Therefore, no cables are required."
This is should be compatible with the camcorder you are using.
Please advise for the results.
Oct 19, 2009 | Cameras
Blue stripes when playback
first u put clean casset and try . again it coming then u chaing video head
Jul 21, 2009 | Panasonic PV-GS2 Mini DV Digital Camcorder
My panasonic PV-GS2 KEEPS ASKING TO USE RESET BUTTON, WHT IS THIS PROBLEM?? HELP
rear operation unit has a faulty flexible cable connection,must be replaced.
Jun 11, 2009 | Panasonic PV-GS2 Mini DV Digital Camcorder
Camera - Canon Powershot S2 IS (5.0)
This is caused by a bad lens motor, contamination in the transmission, or mechanical damage from dropping. The only fix for this is to have it serviced by Canon or other camera repair facility.
Dec 14, 2008 | Canon PowerShot S2 IS Digital Camera
Tape wont eject, play, or rewind. It tries, but soon the message to push reset comes up. No help. Camera works ok otherwise.
put the camera to your ear , power it up and listen ! if it sounds . . . jerky ? your tape is stuck to the heads ( not easy to get out , cassette may be toast and - time is money ) ; if you hear whirring sounds ? before shuts down your cassette housing may be bent ( will need disassembly etc . but not usually expensive ) because - if it is a loading problem , it will usually eject ;
Sep 04, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
PV-GS2 Camcorder is not being detected using Firewire/DV port
Hi Here is a link to the latest manual for your Camcorder. Check out page 42. This may help. http://service.us.panasonic.com/OPERMANPDF/PVGS2.PDF You may need to re-install the software o your computer for the camera inteface. Have a Great Day!!
May 04, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Can not playback past end of first file on my Panasonic PV-GS2
I'm not sure if this will work for you but, sometimes I try to play back some of my tapes and a blue or grey screen comes up instead, although this sounds odd, if I record something(for even one second) it will let me see my film. I know this can cause problems because you may end up taping over film but if it's the only way to see your film it's worth a try!
Jun 02, 2006 | Panasonic PV-GS2 Mini DV Digital Camcorder
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
