Question about Philips Magnavox 51MP392H Rear Projection Television
Phillips/mag PVT-810 8P6044
For a past couple of nights recently, the picture would start to "Shake", I guess is a good description. then once or twice, the picture would sort of
"Wink" out, but then reapear w/ no further issues. Then on occasion
would shut down after this. After letting it set for a couple mins,
turn it on and it would be ok the rest of the night. I thought maybe
loose/cold solder joint some where, because it seemed to come back
after tapping wiggling board sometimes, but what do I know.
Well I had it on this morning for a bit, worked ok, had to go do some
things in town, and shut it off. Come back today and all it will do
now is power up for about 3 seconds, then shut down w/ a real faint
sort of instantaneous "Squeak" sound (luv my descriptions so far???...lol)
This is all it will do now. I got the HV/Vert def board out on bench
lookin @ it now, but not even sure if its on this one or other board.
Was hoping theres a small case history of this issue or if anybody has
an idea on what to check 1st. horizantol output (D2539) seems ok (Q802)
but then again i ask...what do I know.
Well after replacing that diode anyways, i connected back up, now tv
will power on, but no HV, 15watt 30 ohm resistor (R938) near FBT, cold
as a stone, theres another on other side of FBT (R980) that gets
warm/hot. Had a retired TV guy over here last night, but he was a
bull...burnt up a trace/pad tryin to remove a diff diode that was good
anyway's, bitchin/moanin bout not havin service manual,etc..then he
broke the tip of my 100w gun. Hence why I rather do these things myself.
I repaired the damage and put it back together to see what the state of
the union was. Like I said, set powers on now, have audio, but no
HV...vertical looks to be there...I'm afraid I'm lost unless anyone
there has a schematic for this Mag/phil
(That is if anybody is reading this babble)
thanks again
Mark G
  • Max G
    Max G Jul 07, 2008
    between this helpful post, and the service manual i found this morning, I have faith, yes!!
    thank you kind sir
  • Max G
    Max G Jul 07, 2008
    yes old fart here also, 46 on thursday
    tv is 1998 model
    was thrown out in trash because of blue and green crt cataracts, which I've already taken care of.
    picture is sweet and crisp for a rear projection, hence worth trying to repair.
    thanx again!!
    e-mail me if ya want manual for this particular model
  • Philips Master
  • 3,459 Answers
If the video is shrinking and expanding then its likely the opto chip is doa. Its a common problem on the older sets. Check with www.magnavoxhelp.com and see if they have a chip kit for your model.
Posted on Sep 13, 2008
  • Philips Master
  • 5,568 Answers
Jeez, you ramble on as bad as I do (must be another old fart).
It sounds like you know enough to be dangerous.
Getting service literature is not likely, BTW, Sam's Photofacts is not keeping pace with the proliferation of models, brands and re-branding.
Your first description does sound like a cold or fractured solder joint.
If you've had the board out, do it again and inspect the HV area with magnification for solder joints that look cracked.
You didn't mention how old the box is and if it was built in the 2003-2006 period, you may be a late victim of millions of capacitors which failed because of counterfeit and defective electrolytic solution.
Sorting out the good and bad caps needs patience and a cap meter with DF (losses) feature.
Locate the main power supply transformer; it will be about 4 cubic inches and the core will appear smooth (ferrite).
Check the diodes you can identify near that transfomer, you may have to lift one end of some of them since the ohms (or diode) reading you see may have a low-resistance winding parallel and a low resistance load to ground.
It sounds like the PS output for the HV circuit has failed but that may be a symptom of the problem, not the origin.
You've checked the horizontal output transistor (2S)D2539 but made no comment about what you found.
This type has an internal damper diode that can make it look bad if you aren't familiar with it.
Two of the three leads should be desoldered and centered in their mountng hole so they are not contacting.
Pinout is here:
http://www.nteinc.com/specs/2300to2399/pdf/nte2353.pdf
(This is for a replacement type of the same ratings.)
Checking from E to C; with the positive on the collector, the negative on the emitter, it should measure quite high, maybe infinite is all is well.
Reversing the leads will probably show a typical diode drop of something less than a volt (the diode function is supplying current but measuring and displaying a voltage drop of ~ 0 to 2000 millivolts).
The base to emitter and base to collector MAY show values quite close to each other, hundreds of millivolts when the positive (it's an NPN type) is placed on the base and the negative on the other two - separately of course!
Good luck-
Posted on Jul 05, 2008
  • Steve Allison
    Steve Allison Jul 07, 2008
    Hmm, no email address in your profile but maybe Fixya will zap one to you.
    Thanks for the offer but I am not actively doing service any more and I have enough unused 'stuff' in my 'Technical' folder.
    You might post the link for the manual in a return comment so that others can save some time.
Just recently my 1999 bravada has started to shake in the rear what could be the problem?
Hello Jack, This is just a guess. I would check all of the tires for a bulge or bubble.
Mar 22, 2015 | 1999 Oldsmobile Bravada
3 cell mag 1 battery came out the other are stuck. how do i get them out?
Hello, don't bang on the mag lite. Take a four inch deck screw and screw it into the battery one a time. Once the batteries are out. Mix up some water and baking soda.paste Take the soda paste and applied inside the tube around the corrosion areas. Rense with water and paste serveral times until the inisde of the tube is cleaan. Remove all components from mag lite be starting this operation. Wipe out with clean cloth and skake until al lwater is removed. GB ....stewbison
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
2000 grand jeep cherokee limited 4.7 liter, v8, at first wouldn't start rplaced battery because dead and then replaced starter. ran ok for a couple days. last night started it and hard time with it...
Hi
Pop into to your local garage and have a diagnostic test carried out.
Listen to the advise given. It may save you lots of money, especially if you start the "guessing" game.
It does sound like a part may be blocked or failed though, but the sytem needs to be tested thoroughly first.
Good luck
Roger
Apr 24, 2017 | 2000 Jeep Grand Cherokee
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
When trying to take pictures of my motorcycle with all the led lights on at night the pictures keep coming out al blurry or very bright I have tried the settings on night time/ museum/ without the flash/...
Most likely the problem is "Camera shake". This just means that being in the dark, the camera shutter speed is long enough that the natural shake of your hands make the picture blurry.
You've got a couple options. The easiest is to find a nearby object and use it to steady your hand as you take the picture. You can also get a tripod and use the time delay release on the camera. This will let you push the button (which shakes the camera) and then step back before it actually takes the picture.
If you're shooting fairly bright LED's on the bike, you also might go into manual mode on the camera and experiment with shorter shutter speeds. Most people can use a speed of 1/60 without too much blur, so start with that and move to shorter speeds (maybe 1/100 or less). With the manual speed, you may get enough light from the LED's to make a good picture.
If this doesn't work for you, post a comment and I'll check back every few days and give some more ideas. Your camera may have some other ways to work through this. Rear curtain flash would be the best, but I don't think it has it....
Sep 11, 2009 | Nikon Coolpix 4800 Digital Camera
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Sep 03, 2009 | Samsung Televison & Video
Camera seems to ignore all buttons
I have the exact same problem. I purchased a new battery, but still have the same issue. Any ideas?
Sep 20, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Only 3/4 of the screen is being shown...
Ok so I have actually had this happen to me before. My best guess would be that it is a problem with the video card. There may be some video drivers that you need to download. The other explenation might be that the video card over heated.
When it happened to me the whole screen went blank all together after the login screen so at that point it wouldn't load Windows. If you're still covered under the warranty then you're good and set and you could get it within a couple of weeks if you send it to a tech service (preferably the company that built it)
Hope this helped
Nov 18, 2006 | Mag Innovision LT776s 17" LCD Monitor
Philips Magnavox 51MP392H Rear Projection Television Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
