Question about Dryers
Dryer not starting
I have Admiral Drayer Model # ADE7000AYW. The dryer you can hear attempting to start just want start. I have checked the door switch and the switch is in contact. I can hear the clicking as if to start was working just tried to complete a new load and won't start.
Whats my problem?
Nichelle
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Posted on Jul 08, 2008
I have a Admiral dryer that wont start. The symptoms were one day the clothes weren't drying properly the next day the dryer wouldn't start at all.I checked the fuse first with an ohm meter that was g
Sounds like you have a blown thermal fuse. This happens when you have a restricted/blocked exhaust vent. Jump/bypass it, if it works make sure to clear exhaust vent or it will blow again.
Also the door switch - not commonadmiral-dryer-wont-start-symptoms-one#solution-section-p15g0twhbk2df1qsblkfpfhy-1-0.jpg
Nov 08, 2014 | Dryers
Admiral dryer won't turn on or start
It could be a broken door switch. With the door open, look for the plastic tab that comes through the dryer frame. this is the switch. If it is broken, you know what the problem is. If not, depress the tab and carefully try to start the dryer. If it starts, then it is not your problem. I have changed two before. very simple.
Apr 24, 2014 | Dryers
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
Admiral dryer wont come on
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 01, 2012 | Admiral Dryers
I have a maytag admiral dryer (ade7000ayw) stopped working over tonight? It's plugged in and the outlet has power.
The thermal fuse is what the problem very likely is. It is located on the side of the heater housing on the upper part of the back wall of rear drum support. To check it UNPLUG DRYER,remove the 2 white wires on the right side of where the heat element goes and check the thermal fuse for continuty (zero ohms resistiance) using a meter set to measure ohms of resistiance
Aug 12, 2011 | Dryers
ADMIRAL ADE7000AYW This dryer will not start at all. Light inside is not on. There is power at the plug. Is there a internal breaker
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 18, 2011 | Dryers
HI, MY ADMIRAL TUMBLE DRYER WILL NOT START. THERE
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Heating element only turns red when dryer door is open
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
May 21, 2008 | Dryers
Dryers Logo
334 people viewed this question
Top Dryers Experts
