Question about Samsung Vacuums
Samsung jet propel 1800w power clean vacuum not sucking in/picking up on main front edge roller whilst the hose / attachment does have plenty of suction when taken out of its dock
Just had the same problem. Turns out to be the belt that spins the brushes...
Check to see if the brushes are spinning, if not, undo the four screws on the plate over the brushes and the belt is easy to get at. Replacement should be available in any spares store.
Posted on Aug 03, 2008
"Power Brush" attachment doesn't work
When my hover suffered a similar issue i found the problem to be a little stone caught in the part you described as a water wheel, however later i found that one of the connecting hoses from the front of the hover had a little blockage , later, i actually washed the filters and left them to dry over night wrapped in a towel on a warm heater, it was back to normal , the last hover gave in as the motor started to slowly give in , it could be this
Mar 15, 2014 | Vacuums
Model #169171 not sucking up dirt
I have the same problem. When I pull the hose out it seems to have plenty of sucking power though. I dont know what the problem is and why it wont pick up much from the carpet. The stuff it does pick up never seems to make it into the canister either.
Jan 23, 2010 | Kenmore 85930 PowerSpin Deluxe Upright...
Not sucking - not self-propelled.
Problem 1: it could be the transmission causing it not to be self propelled.
Problem 2: Have you checked for clogs in the system?
Aug 11, 2009 | Vacuums
My upright kenmore progressive vacuum will not suction up when using the sweeper. It will suction things when I use one of the tools. I have put in a new bag and have tried to see if anything is blocking...
I believe on the front top part of the vacuum is a cover. you need to take it off. behind it you will find at least two filters. You will need to replace the hepa filter and the other one should be like a thin black sponge, you can just wash that one.
If its not that then there are two clips on either side of the base of the vacuum. Pull those clips outwards, then lift the top off, you will see the tube that the hose attaches to. Pull the hose off and check for debris in there.
I hope that works for you.
good luck
Aug 07, 2009 | Vacuums
Vacuum doesn't vaccum!
Sounds like there is a clog near where the hose conects to the lower brush part.. Try to look up in there.. Under the brush there should be an opening that goes into the hose.. There might be a clog there..
Jul 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My attachments won't ****
Hi
If the machine is picking up from underneath the hose must be blocked. Try dropping a coin into the hose and see if it comes out the other end
Rob
Feb 13, 2009 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Sucked a string up and now the self propel won't work
because you caught up the string, the belt is perhaps broken. turn on and check the roller rotates
Jun 07, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
968 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
Dyson Solutions...
Dyson Solutions...
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
