Question about Intel Computers & Internet
Melfunctioning of USB port
In Intel 810e motherboard, when I connect the Printer USB cable on the USB port a message displays " USB not recognize ". and the Printing job take more time & computer's performance is very slow.
Thanks for the solution, I'll try it then I tell you
sushant tudu
Posted on Jul 24, 2008
    Sergeant:
  • 287 Answers
Possibly have a usb 2 device in a usb1 port.
try updating driver for printer
more help may be available if you post more details like printer model
Posted on Jul 06, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I have used the printer (hp deskjet f4180) for over a year now. but recently when I connect it to my pc (hp windows vita), i get an error message that the usb fevice is not recognised. I have tried to...
If I am right, the error message should be "USB Device is not recognized...." not "Fevice" :-). This happens with most usb devices when there's connection problem, i.e. the USB cables or the USB Ports or the USB interfaces.
First of all try the printer with the same cable on another machine to make sure it works, if it doesn't work, then you'll need to replace the USB cable or try with another cable.
You can also try cleaning he USB Ports and the cables usb jack with a brush dampen with alcohol. Also clean the usb ports on the computer with the same materials mentioned.
These will definitely help you find out the culprit and take the necessary actions, like replacing or switching the usb port.
To simply find out if it's the computer or the printer or the cable, try the printer on another computer.
Note: If it's not recognized once it's connected, then the issue is not with the drivers... If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | HP Office Equipment & Supplies
Hi dear can this motherboard suport intel pIII
Here are the specs. to this motherboard Product Details Intel 810E Chipset, Socket 370, Compatible Processors: Intel Pentium III Specifications Key Features Chipset Intel 810E Compatible Processors Intel Pentium III Processor Max supported CPUs qty 1 Socket Type Socket 370 Memory Number of Memory Slots 2 x DIMMs Audio / Video Video Out Ports 15 Pin D-Sub VGA port x 1 Other Features Package Qty 1 Chassis Type Desktopso to your queston... Yes it supports Intel PIII have fun >.<
Feb 25, 2010 | Dell (002TR) Motherboard
UsB port malfunction message
Check the all functions installed properly.
Go to these steps:
Start > Control Panel >System > Hardware Tab > Device Manager
If errors on USB port presents ,then reinstall intel chip set software,it can install either by the cd that came with your board or that is must downloaded from the intel center.
If these all steps are already given then do following:
Enter bios setup by pressing F2.
Go to Advanced >USB configuration
Set USB 2.0 to enabled
Exit and save changes.
Dec 09, 2009 | Intel DG965RY Motherboard
Printer causes Flash Drive and Ipod to not work
Ipods and the Kodak printer are both high power devices. There are known issues on common intel motherboards with multiple high power usb devices. You may just have this bad luck, and your motherboad printer ipod combo just wont work at the same time. The best advice I can offer you is to get a High Speed Powerd USB hub. Connect either the IPOD or the printer to the hub and connect the other directly to a USB port on the PC.
Good Luck!
Jan 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp laserjet 1020 ( usb device not recognized )!?
I'm not sure, but I think I understand that you're connecting using a USB hub? If so, try connecting it directly to a USB port. Many times an unpowered USB hub does not supply enough power to run a laser printer. Unhook the printer. Go to Printers and Faxes - delete the printer. Hook up directly to a USB port. Let the computer re-install the printer. Let me know Ed
May 05, 2007 | HP LaserJet 1020 Printer
Computers & Internet Logo
74 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
