Question about Snell XA 90PS Speaker
Snell XA 90 speakers
I have a set of snell XA 90 ps with  no owners manual. Is the RCA Jack on the rear that has LFE input the input for the 2 10" subs or is the terminal post that has bass input ?
If you still have these speakers and want to sell, I'm looking for a pair. davewolff@verizon.net
Posted on Jul 10, 2010
Want to sell the XA 90....call me 832-453-1822. regards
Posted on Oct 18, 2008
LFE input is for the subs. It allows us ( I have a set too) to do additional room correction with the on board amp.
Posted on Jul 15, 2008
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
Adding a LFE input to wireless samsung subwoofer
I doubt there is a way to put an RCA jack into that sub. All the input comes from the wireless board. If you tried to put an RCA jack in there, the impedance and signal levels will not match what they need to be. Also, those soundbar system subs don't put out a lot of bass, I doubt it would even improve the sound of your current system if you could get it to work.
May 02, 2013 | Audio Players & Recorders
When I Connect the LFE Output of the Amp to the LFE Terminal of SW, the SW does not work, however, if the speaker output of Amp is connected to SW, it works ok.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Infinity-PS-12-Subwoofers-manual/id/21470dj882/t/2/
I'm assuming your amp for testing was NOT a subwoofer output. I could be wrong.
Your source is responsible for creating LFE output. Are you sure it's doing that?
Tune an FM station and connect any other active RCA output from the source (like a Tape Out) to the sub
Mar 05, 2011 | Infinity PS-12 Subwoofer
Wondering what the 2nd input (red jack) on my PSW140 is for and what the frequency should be set to.
A single or mono bass-specific input would be attached to the one marked LFE (usually the Right).
The sub also supports a full-range stereo signal coming into it on both jacks if your electronics don't break out the LFE to one output.
Dec 29, 2010 | Polk Audio PSW140 Speaker
No output to the subwoofer using the sub pre out RCA jack.
I'm assuming your subwoofer is self-amplified, otherwise it won't work with a preamp (rca) input.
Under Speaker Setup you have to have Subwoofer set to YES (page 16).
If you have good bass-capable main speakers I would recommend setting the subwoofer playback mode to LFE+Main, otherwise just LFE.
Beyond this we would need to know something more about the subwoofer and its controls.
Connect any other preamp out channel, like CDR/Tape OUT, to the sub and tune an FM station to see if the sub is capable of processing audio. A 'normal' audio signal would sound muffled but it would prove the cabling, amp and speaker at least function and point us back to setup as the culprit.
Dec 08, 2010 | Denon AVR-587
I have a constant buzz tone coming from my subwoofer. I checked power connection, fuse and volume/crossover settings and nothing makes the tone go away. is there anything else I can do? Is it repairable?
Hello,if your subwoofer cable has gone bad this will introduce a hum(buzz) into your audio.I suggest replacing the subwoofer cable, a standard rca cable will do,and see if the audio cleans up.
Sep 11, 2010 | Snell PS.10mk2 Speaker
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
My Snell PS10 subwoofer started to make a noise ( Huummmmmmmmm)
Chances are it's a large electrolytic capacitor that's failed. If the sub is a powered one it will be in the power section on the PC board.
Feb 26, 2010 | Snell PS.10mk2 Speaker
How do i use the high level speaker inputs on this snell QBx sub.
Most likely, you simply connect the speaker wires to the high level inputs, along with the cable from your amp.
Given that Snell's are high-end speakers, I would recommend that you contact their tech support for your question. They have a specific email address for technical questions on their Support Page.
Jan 23, 2010 | Audio Players & Recorders
Onkyo 875 suboofer problem
Is the subwoofer got a power? If not then troubleshoot the input power maybe fuse damage.
if there is power, EXamine the connection from the woofer to the output of the source. check the jacket of the of termination.
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Snell XA 90PS Speaker Logo
463 people viewed this question
Top Snell Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Snell Audio Player and Recorder Expert? Answer questions, earn points and help others
