posted by Narayan Chak on Jul 05, 2008
my printer not paper load correctly my printer model epson r230
Solution #1
posted on Jul 18, 2008
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Epson Stylus Photo R300 InkJet
Email this problem
Email this problem
Can you Help with these Printers problems?
Epson Stylus Photo R300 InkJet Printer
Lawrence... is that you
LOL... hey Lawrence It is Mark... Answer This...
Epson Stylus Photo R300 - paper...
When the printer tries to feed... Answer This...
my printer won't turn off
I could not load photo paper,... Answer This...
Epson R300 - tray door error...
You solved my problem about the... Answer This...
Repair Service
Find Printer Repairman Near You:
