Question about Microsoft Windows XP Professional
IP Address I've checked host file, there was nothing in there. Also hit reset, still don't work...any suggestions?
  • WayneFixya
    WayneFixya Jul 05, 2008
    www.boston.com, www.yahoo.com, www.carbonite.com
    Internet Explorer 7
    Comcast.
  • WayneFixya
    WayneFixya Jul 06, 2008
    Network is set to DHCP.
    I've downloaded Firefox, still having a problem.
    Also, my backup system Carbonite can't access the internet. My security settings are set to high and I can't seem to lower it.
    It seems as though certain websites, like carbonite.com is being blocked.
    Any help would be greatly appreciated.
    Thank you.
    Problem Solver:
  • 12 Answers
What pages are you having issues with?
Internet Explorer 6, 7?
What is your ISP?
Posted on Jul 05, 2008
  • xitlife Jul 05, 2008
    Firstly a couple of things to try. Download Firefox, just to see if that browser causes the same issue. If you have no problems i would then uninstall IE7 and try again. Also uninstall any toolbars you have, as corrupted ones can cause issues.
    In your network settings are they set to DHCP or static IP?
  • xitlife Jul 06, 2008
    Hi. I have seen similair things mentioned from other users of Comcast. Have you tried Safe Mode With Networking, at the F8 option screen.
    Have you tried running any Antispyware software such as Spybot, or Adaware just to make sure nothing is happening that shouldnt be.
    In your IE settings have you got proxy server settings set up.
    What kind of router are you using or do you have a cable modem.
    Thanks
Windows 8.1 Store Error 0x80072ee7 Fix?
The 0x80072EE7 error code may occur if the client computer cannot find the correct IP address when it tries to resolve a URL for the Windows Update Web site or for the Microsoft Update Web site. This error may occur if the Hosts file contains a static IP address.
To resolve this error, examine the Hosts file. (This file may also be named Hosts.sam.) Make sure that the file does not list any static IP entries for the Windows Update Web site or for the Microsoft Update Web site.
The Hosts file is located in the C:\Windows\system32\drivers\etc folder. To view the Hosts file, you may have to associate the file with Notepad. To do this, follow these steps:
  1. Right-click the Hosts file.
  2. Click Open With, and then select Notepad from the list of programs.
If the Hosts file contains a static IP address that is associated with Windows Update or with Microsoft Update, comment the entry by adding the # sign at the beginning of the entry. You can also delete the whole line and save changes to the Hosts file.
Note Programs, such as Web accelerators, DNS accelerators, DNS caching utilities, and Spyblockers, can add static IP entries for the Windows Update Web site or for the Microsoft Update Web site to your Hosts file. This scenario can cause Windows Update or Microsoft Update to fail.
Aug 15, 2014 | Lenovo IdeaPad Y510 Notebook
Tip
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g. 192.168.2.101).
If the WAN IP address has a DNS host name associated with it, such as www.example.com, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like:
192.168.2.101 www.example.com www.otherdomain.com # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
Samsung scx-3400 keeps changing ip addresses
Depends on the router you have. Some routers you can set what they call a DHCP reservation for your printer. I'd like to give you specific instructions but it varies by manufacturer and some home/home office routers don't have the feature. Probably the easiest way if that isn't an option is to set the IP address on your printer to a static address. Then on your computers edit the hosts file in C:\Windows\System32\Drivers\etc
Add an entry to your hosts file for your printer. Your PC will now ALWAYS know the IP address to the printer.
Note: On windows 7 you may have to open an administrative command prompt to edit the hosts file. Is usually write protected for security reasons.
Nov 24, 2012 | Samsung SCX-3400 All-in-one Laser printer...
Where is the WEP/WPA code on a Netgear router
The WEP / WPA security information can be obtained by accessing your Netgear router setup page. You'll need the router's IP address to access the setup page. From your computer, go to Start > Run > type "cmd" (w/o the quotes), hit Enter > DOS black screen appears, type "ipconfig" (w/o the quotes), hit Enter. Take note of the Default Gateway IP address - that is your router's IP address.
Pull up a browser and enter the IP address in the address bar, hit Enter. You will then be asked for your router's Username and Password, enter the required information. If you don't know the info, please contact your router manufacturer for assistance. Once you're in the router setup page, go to the wireless security settings to check the WEP or WPA code.
Should you still need further assistance on this matter, please contact your router manufacturer.
I hope this helps.
Feb 04, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Ip address lost
Open your command file by typing the letters cmd into your search entry on your control page, and hit enter.
After the black box opens, type ipconfig/release then hit enter and wait till all the network protocols, host list, gateways etc., have finished listing. Then type ipconfig/renew and hit enter. This will renew your IP address.
Apr 29, 2011 | Computers & Internet
Question
I just helped another person with what is sounding like a common issue, the only difference is they were reporting that the page would come up with page cannot be displayed and their home page had changed to a websearch page. It seemed to me that they had malware that was hijacking their preferences so I directed them to download the coolwebsearch removal tool from trend micro. I'll give you that link too, it's totally worth a shot because it's small and runs quick and it's better to get that possible problem out of the way. Download and run the program below, choose to fix right away as opposed to scan and if it tells you to reboot do it right away.
http://us.trendmicro.com/us/products/personal/CWShredder/
If it doesn't detect anything we're going to have to take the troubleshooting up a notch.
So if that doesn't fix it we need to see if another malware program is redirecting you so you cannot get to yahoo. Go to c:\windows\system32\drivers\etc and open the hosts file. A standard generic hosts file usually only contains this:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
There may be a few lines below the localhost entry but if you see any references to www.yahoo.com then we know you have some really bad malware and need to run a good spyware removal tool. For that I recommend Spybot Search and Destroy and Ad-Aware. I don't really trust anything else really.
If that doesn't work the last thing I can suggest is trying to reach the website by IP address. Go to start>run>type cmd then hit enter. In the command window type ping www.yahoo.com and it should return the IP address. Type that into the address bar in your web browser and hit enter. If it gets to yahoo then you have a DNS issue. Let me know if that is what happens and I'll send you the instructions to change the DNS address on your network card.
Jill
Nov 30, 2008 | Microsoft Windows XP Home Edition
Linksys Wireless-G WRT54G
Try the following on your router
1.) if internal firewall of router is activated, try to disable it.
2.) re-check your DNS settings in the router.
3.) Don't put as local ip address the IP address of the ADSL modem!
4.) Last but not least: if everything fails use static IP setup
Hope it helps...
jowunger
Jul 22, 2008 | Linksys Wireless-G WRT54G Router
No IP address via LAN (+)
what reset did you do?
assuming you reset router by unplugging then plugging back into power source?
back up current config file first, to save your settings, reset to factory settings, power cycle.
Dec 14, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Microsoft Windows XP Professional Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
