Hi: My TOSHIBA 42HP83P works well for first 20-30 min. after that half of the upper screen will discolor or black out. I guess it might be overheating somewhere because it took longer time to develop that problem when i put a fan to cool it off from the back but i noticed that two cooling fans on the upper top of the unit were running. Thanks in advance. Ian Scheeh
  • sch11h Jul 05, 2008
    The is a heavy plasma TV.
    I will do more study before I take it off the wall and open the back
    to replace the fans. One of them was making noise before but there were
    running when I checked them last time. And I could not tell if it ran
    in proper speed or not.
    Master:
  • 497 Answers
Hi.
Jus check the fans whether it has any friction in it and any noise arised....
Posted on Jul 05, 2008
Faint green lines discoloring half my laptop screen
The gas in the screen may have become unbalanced. I replaced my TOSHIBA screen a couple of years ago for $75. on Amazon after both Toshiba and SparePartsWarehouse wanted $167
i had to have a technician install it because the hinges are mighty tricky.
Feb 14, 2013 | Toshiba - Monitor
My toshiba Satellite L755-S5166, half of the screen black. The color changes from green to purple to dark. and I'm only working on half of the screen... what is the problem and How can i fix it
probably your screen has to replaced due to malfunction of card that drives the screen and comes with the screen. some people tried to repair some could and others could not
Aug 29, 2012 | Toshiba Satellite L755-S5166 15.6"...
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
The bottom half of the screen of my old Toshiba rear projection tv is black. It will usually correct itself after about an hour of warm up. What is the problem and how can it be corrected?
Hi ,it has to do with the light engine.Either the DMD board and this it how it works:http://electronics.howstuffworks.com/dlp1.htm Basically if your tv is a dlp it has a chip that carries 2 million pixels when those chips are in the off position you'll get lines or discoloration.God bless you and your family.
Oct 01, 2009 | Toshiba 50H82 50" Rear Projection...
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
Screen
Your LCD screen is broken this occurs from dropping the lcd or putting too much force/pressure on it. The black discoloration is is the liquid crystal leaking. It is repairable but the question is do you want to spend the money to repair it. A new lcd will cost you around $350+. You can also check ebay they might have compatible LCDs that might work for a lot less. According to the specs you need to took for a 12.1" 1024*768 XGA TFT Standard aspect lcd screen but beware not all LCDs with those specs will work. If your interested I am experienced in replacing laptop screens.
Jason(at)JRDTech.net
May 15, 2008 | Panasonic Toughbook W2 Notebook
Toshiba satellite p25-s5263 black screen
i guess your laptop's display chip is not working.
check it with the other one..
thanks
Apr 04, 2008 | Toshiba Satellite P25-S5263 Notebook
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
