Question about Panasonic SA-HE90 Receiver
Problem playing DVD's
Unit worked for many years but now won't play DVD's. When DVD is loaded a "clicking" sound is heard but unit doesn't seem to want read the DVD. Dirty disk lens? And if so how fix. Thanks Kevy Player OK reading shows"No disc"
  • 682 Answers
Bring (cd cleaner)cd from near radio shack and run it until you get good result.
Posted on Jul 05, 2008
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
The dvd player side doesn't want to read all discs. Some it just flashes the loading and makes a clicking sounds, sometimes it loads up and freezes on dvds, it does this when i try to put in a cleaning...
The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Clicking sounds when playing VHS tapes
On one hand I would say not to be concerned about the clicking since nothing seems to be affected. However, if the noise is loud enough to be a bother, or for your own peace of mind, consider returning it to the retailer for exchange if you still have that option. I've heard clicking sounds from other VCRs because of some of the moving parts and it's been nothing to worry about. But I'm not familiar with the guts of your model, so I can't say it's not a sign of some problem that might get worse over time. It's your call. Not really a "solution" I know, but without opening it up for myself and looking for the source of the noise it's the best I can offer.
Apr 25, 2009 | LG RC897T DVD Recorder/VCR Combo
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
Dvd won't load
open it and check for a broken part in one of the gears that operate the drive. if the unit is under warranty, take it back rather than try to fix it.
either something is in the mechanical portion of the unit, or it is badly worn.
i would suspect a broken part from the noise issue/ clicking sounds.
the read head runs on a track and could be jammed up, unable to run to access the directory of the disc. inspect what you can get to, and hopefully that will be a simple fix.
good luck
mark
Jan 05, 2008 | Symphonic SD200E
Dear Kevy, Assuming that the problem was dirty lens, I think that you should try a cleaning disk (preferably the the brand recommended by your player's manufacture, if appropriate.) Was the "clicking" sound a normal one, basing on your previous experience? Make sure that all connections are properly done.
Dec 08, 2006 | Symphonic WF803 DVD Player/VCR
Panasonic SA-HE90 Receiver Logo
143 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
