Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Smeg se375mfx5 / stainless steel
Hi, Took off the oven door to clean it and cant get it back on!! cant find the manuel. getting very annoyed !!!!
    President:
  • 1,462 Answers
I suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Posted on Jul 05, 2008
We need to slam the oven door to switch off the intenal light and make the oven work?
cleaning your oven door switch might help but I would consider replacing the switch. The switches are sealed and cleaning does not work well.
http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Smeg F65 Stainless Steel Electric Single...
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
HI I HAVE A SMEG OVEN MODEL NUMBER SA995XR I NEED THE INSTRUCTRION MANUAL JUST TO SEE HOW TO WORK THE SELF CLEANING OPTION THANKS
Hi I have just installed this oven SA995XR-5 yesterday and have the manual. It doesn't say anywhere it is self-cleaning, just good old elbow grease. Below is what is in the manual.
*I have a question for you. Does the cooling fan in your oven go all the time or does it stop some time after the oven has been turned off (which is what the manual indicates it is supposed to do)?
7.Cleaning and Maintenance
Before performing any operations requiring access to powere parts, switch off the power supply to the machine.
7.1 Cleaning stainless steel
To keep Stainless stell in good condition it should be cleaned regularly after use. Let it cool first.
7.1.1 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
7.1.2 Food stains or residues
Do not use metallic sponges or shapr scrapers: they will damage the surface.
Use normal non-abrasive products for steel and a wooden or plastic tool if necessary.
Do not allow residues of suraty foods (suc as jam) to set inside the oven. If left ot set for too long, they might damage the enamel lining of the oven.
7.2 Cleaning of the oven
To best oven upkeep clean regularly after having allowed to cool, Take out all removable parts
  • Clean the oven grill and side guides with hot water and non-abrasiev detergent, Rinse and dry.
  • The oven should be operated at the maximum temperature for about 15/20 minuytes after using specific products, to eliminate the residue deposited inside the oven.
  • For easier cleaning, the door can be removed.(8.2)
7.3 Door Glass
The door glass should always be kept clean. Use absorbent kitchen paper to clean. In case of tough spots, clean with a damp sponge using regular detergent.
8.2 Removing
Hold the door on both sides with both hands near hinges (A - there is a diagram showing this is the top hinge) and raise levers (B - this lever is a little arm attached to bottom hinge. Flick it up until it catches into groove on upper hinge. Its quite uncomplicated). Lift up the door forming an angle of about 45 degrees and remove. To refit, slide the hinges A in the grooves, drop door and release levers B.
8.3 Oven door seal
To permit thorough cleaning of the oven, the seal may be removed. Before the seal, take off the door as described above. Once the door has been taken off, left the tabs at the corners as shown in the figure.
After cleaning, refit the seal with the longer side horizontal and insert the tabs into the appropriate holes starting from the top ones.
Jan 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Put back smeg oven door
http://www.smeg-service.co.uk/support/index.php?a=3
Here is a link to the pdf file that you can download from the internet for instructions about your door.
Just copy and paste the link into your browser window and click.
Jun 25, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
SA280X or SE280X?
go to google then click on shopping it is the best way to get items hope this helps.
Oct 17, 2007 | Smeg SE280X Stainless Steel Electric...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
341 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
