Question about HP D2835 17 in. CRT Monitor
Desktop screen display goes blue
The color display of my HP Pavilion Desktop has faded away.
It is bluish all the time, I'm sending a sample display, please refer to it.
PROBLEMS
  1. The contrast slider in the display settings of the monitor doesn't work at all.
  2. Only the brightness slider works.
  3. Sometimes while adjusting the monitor angle(when turning it round or side ways), the colors become normal, but that's very rarely.
  4. Sometimes the power button needs to pressed a number of times to do its function, also it sometimes works as a BRIGHTNESS BUTTON.
A local hardware repair shop suggests the change in the COLOR IC of the monitor which will cost around INR(Indian National rupee) 600-800/- or
15-20$.
Please tel me what will be appropriate to do.
Please HELP!!
    Problem Solver:
  • 7 Answers
Can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Posted on Jul 21, 2009
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Nov 27, 2013 | HP Black Pavilion 20-b013w All-in-One...
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
Screen fade to white
Firstly, May be the drivers are corrupted, reinstall the drivers again (uninstall>restart>install drivers and restart).
If it doesnt solve yet then change the slot, put it in other slot.
Apr 23, 2009 | HP Pavilion dv9000t Notebook
Display issues blue lines down the screen then green color matrix keeps flashing
If the lines change or go away when you move the lid up and down, then you need a new LCD cable. If they stay the same, then you need a new LCD.
Please note: That test is NOT fool proof, but does work 99.9% of the time.
Apr 15, 2009 | HP Pavilion dv9300 Notebook
Green Blob and Fading to White
Hi, i understand ur problem and try to the following steps. Shut down the NB and turn it on and repeatedly tap F10 key until you see a blue screen and then tap F9 key once and load the bios defaults. Wait for some time and check if u can see the lines and the green blobs. If u still see the same on the screen, it means that there is some problem with the mother board. If u have still warranty left on the laptop, contact the technical support of HP so that they will take the laptop for service. This will definitely work
Thanks and Regards
Honey
Jan 12, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion Laptop Screen
Bearing in mind you mention the viability of cost, I'm thinking your laptop is out of warranty. This does sound like a pretty major problem, one which HP need to look at. You can always approach them for a quote first, with a min/max price, before you decide whether to go ahead or not.
May 27, 2008 | HP Pavilion dv8000z Notebook
HP Pavilion dv6000z (6125se)
Good day, Marc!
Could be a loose cable or bad LCD unit.
Here is a link to the maintenance manual:
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 04, 2007 | HP Pavilion dv6000z Notebook
HP D2835 17 in. CRT Monitor Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
