Question about Kenwood Audio Players & Recorders
Kenwood kr-720 250 4amp fuse blows when power is turned on
  • Anonymous Mar 25, 2014
    When I player my record player or listen to the radio, the sound would go in and out. Do I replace the fuse?
    Genius:
  • Kenwood Master
  • 1,550 Answers
The audio amplifier IC on your device are damaged.
Posted on Jul 05, 2008
Where are the fuses located in a kenwood , kr5030 ?
If there are any fuses you will have to take off the cabinet to see them on the inside. If not the fuse then it is most likely the power supply inside.
Jul 17, 2014 | Kenwood Stereo Receiver Am/fm Model...
My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Dec 31, 2012 | Audio Players & Recorders
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 18, 2011 | Kenwood KR-V5580
Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
Kenwood kr-a4060 keeps blowing fuses
Check the audio amplifier Ic maybe its fried.
Aug 25, 2008 | Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Oct 25, 2007 | Kenwood KR-X1000
385 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
