I have a Logik LCD TV and when I switch it on it justs clicks as if the started isnt kicking in Can you help please Chris
  • 372 Answers
Hi.
What is the model number of your Logik tv ?
Posted on Jul 05, 2008
  • Edmund Wozencraft
    Edmund Wozencraft Dec 08, 2014
    hi, i have the same problem, and our model is the L32he12
Sony tv model kdf 50e2000 shuts off and red light blinks 3 times.
You need to open up set and clean out all fans of dust or the new bulb isnt being cooled, or the color lcd isnt being cooled shutting TV off.
Apr 17, 2010 | Sony KDF-E502000 50" HDTV
Logik 32'' lcd tv dead
hello check the glass fuse inside the tv it will be in the power supply
regards
shaun
Mar 11, 2010 | Televison & Video
Bush lcd wont switch on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter, or faulty LCD controller board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 05, 2009 | Televison & Video
My tv model is 43pp8421. when i turn it on, it has a clicking sound and no picture and sound
hello i hope i can help you. may i please ask you. is the clicking sound like a burr?? or it just wont start? if you have a multimeter check the fuse check to see if a break on the mains cable if ok? if ok open tv up and do a voltage check to see if the tv is receiving power? please check the speaker.S? also check the switch. if power is going in but no power on the other side of switch the switch is faulty also check the volume control.
May 04, 2009 | Philips 43P8341 43" Rear Projection...
Noisy transformer oon logik lcd tv model lcxw 32 hd1 power panel amo1 2004/02 version 1
Hi.
Providing the noise is not causing any picture or sound problems then the noise from the transformer is from the windings vibrating at A high frequency.
To prove this remove back from set & switch set on IF YOUR UNSURE OF YOUR COMPETANCE TO TOUCH LIVE CIRCUITS PLEASE TKE YOUR TV TO A REPAIR SHOP.
With an insulated item eg plastic pen or piece of wood push against transformer can you alter the pitch of the noise or make it stop alltogether by doing this.
If yes This can be cured by applying an epoxy resin type adhesive over the windings this will cure & pot the transformer which if done correctly will stop making the noise,
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
Panasonic PT-45LC12 just turned off?
having the same problem, after some research, came across this: http://www.fixya.com/support/t142873-panasonic_pt40lc12_blinking_green_power
Not a tech, so I'm going to look into it further on how hard this is to do.
Jun 27, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Clicking sound!
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Apr 11, 2008 | RCA P60921 60" Rear Projection Television
The bulb doesnt light up when switching on!! brand new bulb also been fitted
Hi.
Your friend could be right but before spending more money check the cooling fan is free to spin the bulb will not start if the fan isnt spinning.
http://dysonmanuals.inc.io/
Chris.
Nov 08, 2007 | Televison & Video
Televison & Video Logo
593 people viewed this question
Top Televison & Video Experts
Electro Med Services...
