Question about Neff Microwave Ovens
Microwave oven the door has come away from the oven. Nothing appears to be broken as such but how does one get the lower part of the hinge assembly back into the door frame properly. The top section with the extended arm and hook goes in easily, the bottom section a short arm, does not stay in place. Please advise.
  • Neff Master
  • 9,098 Answers
I would contact Neff about this issue to see if they will offer you service advice or refer you to a servicer.
Their contact info is here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
How to remove oven door on Kenmore Model 66504493392
The exploded parts view of this oven appears to show that you can access the upper and lower door hinge tabs by removing the outside cover.
Jun 26, 2016 | Kenmore Microwave Ovens
How to repair a broken lower door hinge?
You may need to remove the microwave off the wall but lets try this first. Unplug the micro and then remove the screws around the bottom cover plate. The cover should drop down--watch the wiring to the light system mounted to the cover. Now look at the bottom hinge area. Can yo see and access the screws to the hinge??? Should be 2 or 3 screws. If you can get to them then you can change the hinge there. Tape the door in place so it doesn't drop while doing the repair. If you can't see the screws, you may need to pull the micro off the wall and remove the outer case to do the repair. In some rare cases the hinges are welded to the case and not replaceable.
Mar 30, 2015 | Frigidaire PLMV169DC Microwave Oven
Oven has power, but will not turn on
It sounds like the door is seriously out of alignment preventing the door latch from engaging properly. The hinges can be loosened and the door can be adjusted to some extent.
Nov 14, 2017 | Sharp R305KS Microwave Oven
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
LG Microwave Countertop Microwave Oven LRM2060 ST. The glass on the outside of the microwave door is broken. Can you order just the glass from somewhere and can I fix it myself?
Due to the serious potential for RF leakage, these doors are normally sold as a complete unit assembled by the manufacturer. I could only find the door listed at repairclinic.com for about $80. If you wish to repair yourself, the old door comes off by opening it all the way and lifting straight up at the hinges. The door will then lift off the hinge pins. Reinstall the door new door by aligning it with the hinge pins and allow it to seat straight down. A simple repair.
If you have any questions about this repair, or require addtional assistance, please let me know. I hope this helps you.
Aug 11, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Frigidaire PLMV169DC Microwave Oven
Front panel of the door just came off in my hand -
The inside hinge assembly may have to be changed. The hinge assembly may be defective. Some of the parts may have fallen inside, and must be found or replaced as necessary.
You cannot simply put a door back on a microwave oven even if you changed the hinge assembly.
If you have any issues with the door or case assemblies, the proper radiation testing has to be performed to make sure that there is no microwave radiation leakage when the unit is being operated. This is very serious!
http://www.safety.uwa.edu.au/policies/microwave_oven_safety_guidelines
http://www.pat-testing.info/microwave-safety.htm
http://www.hps.org/hpspublications/articles/microwaveoven.html
Jerry G.
Dec 27, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
Microwave Ovens Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
