Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Error message E18 - Canon PowerShot SD300 / IXUS 40 Digital Camera
  • 4 more comments
  • mels441 Jul 08, 2008
    Error E18 - Canon Power Shot A95
  • PeanutMP Jul 21, 2008
    Error message E18. The camera shuts shortly after being turned on and leaves the E18 display on a black screen.
  • NS Gautam Jul 31, 2008
    My camera cannon powershot A400 firstly dropped from my hand in april
    2006 when I was in Antarctica. At that time camera was on in photo mode
    after dropping the lens was struck. Then by opening the camera saw one
    lock was brocken of the lens holder which jammed the lens movement.
    After removing the broken peice it works till 28th July 2008.
    Yesterday my daughter report that camera is not working and showing the error E18.
    Now what can be possible cause of this problem kindly suggest
    Narendra Gautam
  • vividp Sep 08, 2008
    I went to turn on my Canon Powershot A95 and the lens opened and then it made a couple beeps and then the lens closed. It then made some clicking type noises and then beeped again. Then the E18 message came on the screen.
  • danstaples Oct 31, 2008
    camera shows e18 on a black screen, and will not turn on beyond that.
  • flathead836 May 12, 2009
    Hi!
    I have the problem with my Ixus 40 that it will not focus when I have zoomed all the way out - when I'm close where the lense have not moved (it turns a little bit when zooming all the way out) there is no problem with the focus.
    Anyone experinced the same problem or similar.
    Thanks in advance søren
I had the same problem with my Ixus40. It can happen i.e. when dust or sand blocks the small gearwheels which are moving the lens.
I disassembled it (be careful with these foil-wires and connectors on the motherboard) and cleaned the gearwheels. There was just a little bit of dust and one grain of sand.
After assembling it back I got a white screen, because I did not connected one wire proberly back...
But after fixing this connection problem the camera is working again!
Regards,
Tobias
Posted on Dec 01, 2008
Not many people will like this but E18 Error message came up after I dropped the camera. After looking for a cheap fix I came across the advice to hit it or drop it! As the camera is about 5 years old and I'm looking for a new one so nothing to loose I dropped it onto a carpet floor and hey presto its working again - and has been OK for several hundred pics since
Posted on Nov 02, 2008
at my A80 the following Link solved my problem properly.
http://photography-on-the.net/forum/showthread.php?t=5700
Best greets
Martin
Posted on Jul 29, 2008
I am getting a message E18
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
In this link could check additional details: e18error.com
Hope helps (remember tp rate this answer).
Mar 29, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon powershot sd500 e18 error message
E18 is lens error , it means that the lens are stuck.
Oct 15, 2008 | Cameras
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
E18 error on Canon ixus40 - lens stuck
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
How can i ix the cannon message e18?
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 20, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera got wet and is now showing a e-18 message
e18 is a general error code for canon. if you got from best buy repost if you got the accidental plan from them
Apr 29, 2008 | Canon PowerShot A75 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
378 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
