Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Machine not pumping out
Cycle washing dishes then not pumping out water lights 1 & 2 flashing
  • Anonymous Mar 25, 2014
    The machine don't pump water out
Blocked pipes or no power to pump, check in that order, but clean any filters out first, cheers
Posted on Jul 07, 2008
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Machine stops part way through the cycle and the light keeps flashing
hi there could be a few problems here 1 check the filter if has one 2 check drain hose at the back of the washer 3 check water pipe make sure there's water going into the machine 4 check pump underneath the washer hope it helps
regards
shaun
Nov 17, 2011 | Washing Machines
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
155 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
