Question about SanDisk Sansa e250 MP3 Player
My sansa is spazzing out
So I turned on my sansa last night, went to my music, went to songs, and to my surprise found that it was 'empty'. Then it faded out and froze. I restarted it and went to my videos, which were working fine, but the songs still weren't showing up. Now whenever I turn on my sansa, it fades out to white before it gets to the menu, or it gets to the menu but then it starts turning blue or green with weird patterns. I've tried going into Recovery mode, but it says I need to enter "USB2.0 MSD mode". I also tried reformatting it, but it told me that the format failed. I need helllp.
  • charcal Jul 05, 2008
    My player freezes before I can get to the menu.
  • 8,596 Answers
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Posted on Jul 05, 2008
  • Corey Knoettgen
    Corey Knoettgen Jul 06, 2008
    You may have to substitute REC for volume +:
    These are the most common methods for recovering Sandisk's Sansa Mp3
    Players. I have been almost universally successful in recovering Sansa
    players using one or a combination of these methods. These methods do
    not work if you are having synchronization or music format issues -
    they are for recovering a player that will not power up, freezes,
    flashes, is not recognized by the computer, and a host of other issues.
    Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
    Download the Sansa Recovery Tool from the Sansa website.
    Format - Erases Everything: Connect your Sansa player to the
    computer and open Windows Media Player. Click on the Sync tab. Pull
    down the drop down menu underneath the Sync tab by moving your cursor
    over the Sync tab and left clicking on the little black arrow
    underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary
    slightly), and then select "Format." - this should erase everything.
    Firmware Upgrade- Erases Everything: Get the latest firmware
    upgrade from Sansa - it updates the firmware and erases every song in
    the player all at once. Note: this method doesn't work if already have
    the latest firmware. Go to this website and click "Firmware Updater" to
    find out: http://www.sandisk.com/DriverDownload/dr...
    If these fail, then:
    Try this: disconnect the player from the computer, turn it off,
    hold in the volume + button, and reconnect the player to the computer
    while holding the volume + button in. Keep holding the volume + button
    for an additional 5-50 seconds. Windows should eventually go into
    recovery mode and revive the player- it will pop up a window that says
    Found New Hardware Wizard.
    If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
    You may have to restart your computer after each of these methods
    to get them to work properly. Disconnect your Sansa player BEFORE
    shutting down your computer.
    -Tha Mp3 Doctor
Sansa Deleted my music?
Your music is still there, check out my tip posted here...Solve your MP3 Player Connection Problem.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa Clip lost all the music I had stored. It
You go to Settings, check System Info, check number of songs in there. If they are existing, you should change to MTP or MSC to play it. Or go to Settings, Reset All, Yes. Try it.
If you accidentally formatted it, can't restore them.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
How do I delete duplicate songs from my e280 song list?
How are you supposed to download music into a sansa mp3 player.. I am a beginner so please make the instructions as simple as possible and quick!! =))
Thanks.. =))
Mar 14, 2009 | SanDisk Sansa E280 MP3 Player
Music on the hard drive but wont show up in music files.
on the player: menu, settings, system, update ARClibrary.
Mar 07, 2009 | Archos 605 WiFi Digital Media Player
SanDisk Sansa Clip 2GB* MP3 Player
Switch the player from USB to either Auto or MTP mode. Or, you can transfer ALL songs in the manner you have just described. Either way.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 2GB no work duplicate the song
Edit the ID3 tag of the files in full before reloading them to your player.
Sep 04, 2008 | SanDisk Sansa e250 MP3 Player
I have a sansa e260 and i can't get into deleting songs
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Aug 06, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
116 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
